Posted by roy entwistle on 17/01/2017 21:39:12:
Michael The dull thud is probably more of a clunk, however a magnet is attracted so I'm going for cast iron
Neil There is a hole across one end for the sashcord. I've never come across one with a hole up the middle
Roy
I am going to come in here because I think i have seen quite few sash weights in my time. When i moved my factory shortly before selling my joinery business I took the left over sash weights to the scrap yard & there were 9 tonnes.
Some sash weights had a hole through the centre top inch down to a cross hole so one could put the knot. Good in that it allowed the weight to go right to the pulley but not so good that the edge could dig into the box. Others had a tapered end with a cross hole. Better in that they did not grate on the box so much but if the carpenter did not tie the knot tight they took up more room. Make weights, designed for increasing weight where one needed to due to the initial weight being undersized were usually about 1/2 to 1lb & had a hole right through so the cord could pass through & tie to the main weight. We used to see how many different forge names we could count cast on the weights of the old ones.
We had lead weights that more often had a hook cast in, square steel weights with hooks welded on & some with holes drilled. The largest weights would be about 34 – 36 lbs & the average 12 lbs although I had hundreds in the 6 & 7 lbs size . Shape would vary from round to square. size from 1 inch to 2 inch across
As for quality – some times we might cut one down & some were like honeycomb & would break somewhere else whilst being cut & some were really close grained. You takes yer pick
I just wish i had kept a few, but i mentioned in the pub last week i wanted some & 2 have turned up unannounced on my drive, so who knows in another 25 years I might have some more
I made quite a few sash windows in 25 years & sometimes had orders for up to a 800 at a time.
