Hello Thomas,
There IS room for an ER32 collet holder, because I've tried it. I had to grind a shoulder on the rear of the threaded portion of the holder (behind the nut) as this diameter fouled the detent knob which projects forward of the face of the Quorn toolholder.
This is the knob of the spring loaded peg, which acts as the detent for a dividing wheel located on the rear of the toolholder. It's located in the toolholder casting just below the one inch bore where the collets were designed to fit.
But it was no problem to do this, I just put a handle on the back of the ER 32 holder – on the one inch portion sticking out of the toolholder and held it up to the grinding wheel until I'd let out enough sparks to make the ER32 holder fit snugly against the tool holder where it belongs.
I don't know of any real advantage of the ER32 size over the smaller one, as either will take a 16 mm endmill to sharpen it. But the Quorn that I bought did not have the tool holder collets included, so I thought buying something to use the ER collets was an easy answer.
I also changed the original 0 – 360 calibrated dial for one which was calibrated 4 times +/-45 deg, as I only use it to sharpen end mill and slot drills with either 4 or 2 flutes. I don't bother with the detent idea for this, it's quicker to index the cutter being sharpened on my 45 deg scale. Oh, and I've abandoned the pretty but ineffective threaded collet thing that clamps onto the outside of the one inch tool holder, in favour of a simple split clamp with a tangential cap screw.
HTH, if you would like to see pictures I can do that but it's cold and dark out there just now!
Best rgds Simon
Edited By Simon Williams 3 on 01/02/2017 22:41:51
Edited By Simon Williams 3 on 01/02/2017 22:48:42
