Boiler Design – issue 4765
Home Forums Model Engineer & Workshop Boiler Design – issue 4765
Viewing 3 posts - 251 through 253 (of 253 total)
  • #811189
    Nicholas Farr
      @nicholasfarr14254
      On JasonB Said:
      Well if proof were needed that AI does not get things wrong, have a look at the latest GROK of S**t it has come up with posted on MEinT hialand’s forum.
      How anyone can post something containing the statement “e.g., 6” diameter ≈ 0.34 liters” as a way to discredit Mark De Barr’s reply is hard to understand. Even if the 6″ diameter were used to work out an area without the missing length there is no way it could even approximately equal a volume. And you don’t need to be an engineer or have letters after your name to spot that GWOK has got it wrong 😉
      Even AI itself s\ys the statement is incorrect, or should I not believe that either😂😂😂
      AI boiler
      Hi, doesn’t even get the area of a 6″ circle correct by the look of it.
      001
      Regards Nick.
        Did not do very well with the Sphere either as a 6″ sphere would be 1.85lts
        sphere
        #811196
        Nicholas Farr
          @nicholasfarr14254
          Hi JasonB, long long while since I learnt how to work out sphere volumes, but I did find a calculator online, which gave the answer by just putting the parameters in, but I then found a formula to work it out, although it took a little time to understand it, which is shown in Cu. mm. I did think the one shown in the post was wrong though.
          002
          Regards Nick.
