Best Parting off tool
Home Forums Workshop Tools and Tooling Best Parting off tool
Viewing 25 posts - 1 through 25 (of 43 total)
  • #330629
    richard 2
      @richard2
      Have just read all the blurb on the Eccentric Engineering parting-off tool so am asking what other people think?
      I know there are a great many opinions and threads on this subject but I do like to ask before I spend a fair amount of money.
      My lathe is a Myford Super 7B with two rear tool posts – one a Myford which is a heavy block and the other is home-made taking a QCTP.
      Have looked at other makes and need a new p/o tool for the rear tool-post
      So suggestions, please.
      Many thanks
      richard 2
      richard 2
        @richard2
        Ask and ye shall receive…..
        #330630
        blowlamp
          @blowlamp
          Keep to a narrow tool on that size of lathe. I use a 2mm wide GFN style insert with positive rake geometry on my Mini-Lathe from the front toolpost, with no issues, so it should be fine with your setup.
          Martin.
          #330640
          Mick B1
            @mickb1
            I use a Chronos (I think) holder with a 1/16 x 5/16" HSS blade.
            It's cheap, adjustable, and easily does everything I can remember up to maybe 2 1/2" diameter – wood, delrin, brass, phosphor bronze, LG2, BDMS, titanium, silver steel. I can't see that I'd want anything better unless I started making batches of several tens or more – and then it wouldn't really be a fun hobby, would it?
            #330641
            ega
              @ega
              Gary of Eccentric Engineering makes a persuasive case for his Front or Rear p/o toolholder. I bought one for use on my larger lathe but found the 2mm blades I opted for rather fragile and pricey (I believe he offers blades down to 1mm wide). I am now using a tangential insert tool from ISCAR.
              On the Myford, I long ago made the GHT rear toolpost and, by and large, it does everything I need. I had one of the KIT-Q-CUT insert tools from Greenwood Tools for a time; this worked well but I found the cost of replacement blades uneconomic.
              My personal preference is for p/o tools with minimum overhang on the Z axis.
              Edited By ega on 05/12/2017 18:01:14
              #330643
              ega
                @ega
                Mick B1:
                Your impressive feat of parting off 2.5" dia silver steel with that blade makes the point that the "best" toolholder/blade and/or insert combination will be of little use on an unsuitable or badly-adjusted lathe; speeds, feeds and lubrication are also important.
                Edited By ega on 05/12/2017 17:58:39
                #330649
                  Greenwood have a new replacement for the Kit-Q-Cut coming soon, hopefully some news in the next MEW.
                  ega
                    @ega
                    Posted by Neil Wyatt on 05/12/2017 18:09:20:
                    I shall read this with interest as I always thought the original design was rather basic. I hope the news will include information about the reasons for any changes.
                    #330660
                    Mick B1
                      @mickb1
                      Posted by ega on 05/12/2017 17:57:08:
                      Mick B1:
                      Your impressive feat of parting off 2.5" dia silver steel with that blade makes the point …
                      Well, I didn't mean to exaggerate, but I don't think I've ever seen 2.5" silver steel – that just got into the list through sloppiness on my part. But I have parted 60mm. EN8, and that can be quite argumentative… blush
                      #330665
                      Vic
                        @vic
                        I like the T shape blades that Chronos sell.
                        They are the best parting blades I’ve used to date and I no longer feel the need to use expensive insert parting tools anymore.
                        #330666
                        Geoff Theasby
                          @geofftheasby
                          I've just bought a Chinese tool costing £10, using MGMN200G inserts. I considered Greenwood, etc., but £70 is a lot to pay if it doesn't work. Even the competition at £30 is quite dear.
                          Geoff
                          #330671
                          Muzzer
                            @muzzer
                            APT Tools also stock various MGMN-type grooving / parting tools in various widths from 1.5mm to 6mm. Their 2mm one is £15. These tools cut sideways as well as parting but the max parting depth is limited due to being double-ended. You can also get rounded "profiling" inserts and the inserts are available uncoated for aluminium machining.
                            Murray
                            #330673
                            Chris Evans 6
                              @chrisevans6
                              I think it is more to do with the condition of the lathe than the tool. I use a 2mm tipped blade from ARC on a home made rear tool post. It works very well up to 2" diameter EN1A and well on smaller tougher stuff. After that it is operator wimping out and sawing rather than risking scrapping the work !
                              #330674
                              SteveI
                                @stevei
                                Posted by ega on 05/12/2017 18:31:51:
                                That is interesting. I've been using the Greenwood Kit-Q-Cut for the last few years. It parts like a hot knife through butter, but I've worn it out, the holder is slightly bent and it no longer retains the tip.
                                Due to the high cost I've now switched to GFN inserts and regular SGFH blade and holder.
                                Steve
                                #330677
                                richardandtracy
                                  @richardandtracy
                                  I bought an MGMN style toolholder + 4 double ended inserts for under £9 from e-bay seller cskwin2015. That was earlier this year. I have done a fair bit of parting with it (by my standards) and there have been a couple of times when I'd have expected my £9 HSS tool to shatter. No trouble from the MGMN tool even at 2mm wide on my Warco WMT300.
                                  So, have to back Muzzer's assessment, worth getting, but with limitations and benefits.
                                  Richard.
                                  #330683
                                  Harry Wilkes
                                    @harrywilkes58467
                                    I have one of the Eccentric Engineering parting-off tool mounted in the rear toolpost on my myford S7 best thing since sliced bread as far as I'm concerned ! Previously I was one of the guy's that struggled with part off but since fitting the Eccentric Engineering parting-off tool I don't have any problems.
                                    H
                                    #330695
                                    Hopper
                                      @hopper
                                      Mate of mine bought a T shaped parting tool blade and holder from Eccentric. It has a strip of carbide along the top of the T. He uses it for putting circlip grooves in the outside diameter of hardened steel bearing races about 50mm diamter — in a mini lathe. Can't complain about that for performance.
                                      #330696
                                      Nick Hulme
                                        @nickhulme30114
                                        For general parting and large work I use a Glanze holder with 3mm inserts in the front QCTP on my Super 7.
                                        For plastics I use a HSS tool honed to a very fine edge.
                                        For thin walled work I use a HSS tool with a slight angle on the tip to ensure a clean cut on the section parted off.
                                        For Polyurethane and thin walled plastic work I use a Stanley Knife blade superglued to the free end of the Glanze holder in the rear QCTP.
                                        For Brass and light batch jobs I have an inverted HSS blade holder for the rear QCTP
                                        Having the blade vertical and parallel to the slide travel are both critical to a good parting experience, good spindle bearing adjustment is a big help too.
                                        #330720
                                        ega
                                          @ega
                                          Posted by Hopper on 05/12/2017 23:08:34:
                                          Hopper:
                                          I couldn't find this interesting item on the EE website.
                                          #330723
                                          John Haine
                                            @johnhaine32865
                                            I use 2. One is a Kit-Q-Cut from Greenwood bought a long time ago which is excellent (in a standard Dickson QC holder), I think I'm on my second insert. The other is a rear p/o tool I got from Kirjeng that takes Dickson-style QC holders, and I have one designed for a wide blade 2.5mm wide. I grind this with a hollow in the top surface (made with a diamond needle file) to curl the chips in (like the Kit_Q-Cut).
                                            They both work very well, but I use the kitqcut usually since the rear toolpost gets in the way and I can just put it on the Dickson post when I want to part off.
                                            #330724
                                              Posted by ega on 06/12/2017 10:15:09:
                                              Hopper:
                                              http://www.eccentricengineering.com.au/index.php?option=com_content&view=article&id=31&Itemid=45
                                              #330725
                                              Mick B1
                                                @mickb1
                                                Posted by Neil Wyatt on 06/12/2017 11:11:33:
                                                Hopper:
                                                I don't think my HSS blade would have a prayer on hardened races, but that's rather an outlier of a requirement and I've certainly never needed to do anything like that.
                                                Even the link admits in the notes at the end that conditions and techniques for parting can be highly idiosyncratic. That old cartoon set I keep seeing here and in magazines illustrates only the extremes of a multidirectional spectrum.
                                                I think nothing is ever perfect in all conditions, and that there ain't no best parting tool.
                                                #330726
                                                not done it yet
                                                  @notdoneityet
                                                  Mick,
                                                  I think you may have missed this bit:
                                                  #330727
                                                  Mark P.
                                                    @markp
                                                    I’ve been using a T shaped parting blade from Chronos, made my own holder myself, best parting blade I’ve ever had!
                                                    Mark P.
                                                    #330734
                                                    Mick B1
                                                      @mickb1
                                                      Posted by not done it yet on 06/12/2017 11:38:54:
                                                      Mick,
                                                      Nah, saw that 😀 – and I'm sure it's good if you're trying to cut hardened stuff, but that doesn't necessarily make it the answer to every issue.
