Ah, that explains why my thous are so often not as meant… I must be using too varied a mixture of old tools…
Further to BA, its diameters were originally metric and in geometrical progression, but of course some committee of bureaucrats decided the odd numbers surplus to requirements, so broke the series!
I have looked at some common thread and spanner standards. BS and ANSI go by screw diameter in mainly logical steps, and their flats are generally to constants or at least logical.
The SI M-series though… How did they generate it? Perusing my poster-size Tracy Tools chart shows it is not at all as consistent as it likes us to think. It follows regular increments for a few sizes, then suddenly jumps to another set. There are any number of M-fine pitch variants and intermediate diameters.
The flats for the common medium sizes are rounded from 1.6D, 1.5D for larger. So why a 17mm (not 16mm) spanner for M10? Below M5 the sizes seem very arbitrary indeed.
M5 – 8mm A/F (1 : 1.60)
M6 – 10mm (1 : 6r)
M8 – 13mm (1 : 1.625)
M10 – 17 (1 : 1.7)
M12 – 19 (1 : 1.583r)
M14 – 22 (1.57)
M16 – 24 (1.5)
M20 – 30 (1 : 1.5)
M24 – 36 (1 : 1.5)
Commercial flange-nuts' stamped, tapered profiles need anything but the nominal M-series spanners.
One of my Round Tuit moments is to equip some of my Myford 7's modern-made accessories with coherent fastenings:
Moving the rear tool-post needs a 5/16 –inch (BSF) and 17mm spanners; the fixed steady's clamp-nut seems from the ISO-Fitnowt range.
The milling-machine's clamp-set (the common commercial type) is all 3/8-inch X 20, either UNC or BSW, but needs a 17mm spanner. I have ordered an M6 clamp-set and it will be interesting to see if a 10mm A/F spanner fits it. Holtzappfel in Swiss inches?
One of my tilting vices has a large nut and 4 screws, apparently all metric but fitting only an adjustable-spanner.
The slitting-saw arbour nut is of Not-Known-Here-Guv A/F but co-incidentally fits (ish) a particular, ancient and very rusty spanner of uncertain parentage I found lurking in the Harrison lathe's chip-tray…
Sir Joseph Whitworth set out to end this palaver…..
