BA threads. Why the tpi?
Home Forums General Questions BA threads. Why the tpi?
Viewing 25 posts - 1 through 25 (of 64 total)
  • #25578
    jimmy b
      @jimmyb
      jimmy b
        @jimmyb
        I’m looking to make up some extension rods for a gauge. The thread is 2BA.
        This where the fun starts for a Sunday. I’ve got taps and dies that size, but thought I’d screwcut them, to get threads perfectly in line. 31.35 threads per inch? Converts to .81mm pitch?
        Who thought that was a good idea?
        Jim, (now spending the rest of Sunday reading about threads)
        #322817
          It is quite logical.
          0BA is 1.0mm pitch you then just keep multiplying by 0.9 so
          1BA 0.9mm pitch
          2BA 0.81mm pitch
          Playing about with your change wheels should get you close enough
          Edited By JasonB on 22/10/2017 13:33:23
          #322818
          NJH
            @njh
            Hey Jim
            BA stands for BRITISH Association none of yer newfangled European stuff here so forget the .81mm and embrace the (almost) perfect symmetry of 31.35!
            devil
            Norman
            Edited By NJH on 22/10/2017 13:42:41
            #322819
            Anonymous
              Posted by jimmy b on 22/10/2017 13:27:44:
              The British Association. thumbs up
              Mathematically the pitches follow a strict geometric progression, rounded to 2dp.
              #322823
              jimmy b
                @jimmyb
                I just don’t see a rhythm with them. Weird tpi and doesn’t convert to milimetric clean…..
                #322824
                Rick Kirkland 1
                  @rickkirkland1
                  Mmmmmmm, BA. Strong threads in small sizes. I remember learning about the genius of this geometry probably 50 or so years ago. None of yer stupid weak knee’d metric ISO malarky and all that sails with it. Viva le BA.
                  #322825
                  Anonymous
                    Posted by jimmy b on 22/10/2017 14:02:51:
                    I just don't see a rhythm with them..
                    It's there in the mathematics; rather more logical than the arbitrary tpi values used for other thread series.
                    #322838
                    jimmy b
                      @jimmyb
                      I’ll do some research……
                      #322840
                      jimmy b
                        @jimmyb
                        Not metric like you might expect, but with diameters determined by a factor proportional to a power of the logarithm to the base 10 of the thread pitch in millimeters.
                        I think it’s time to move on…
                        #322852
                          @mike89748
                          When I were a lad… we regarded 2BA and 3/16 BSF as interchangable. Not quite true, but in many practical situations it does well enough.
                          #322853
                          Andrew Tinsley
                            @andrewtinsley63637
                            Jimmy,
                            It is perfectly logical, in fact if you care to research, you will find that BA is a superior thread standard than the Metric ones.
                            I appreciate that your comfort zone is Metric. I matured on Imperial measurements and then had to use Metric for my scientific career. So I am ambidextrous as it were. Please don't knock what is a perfectly logical imperial system, just because you are not comfortable with it!
                            Each to his own and I would not dream of knocking the metric system, so give Imperial people the same courtesy. each system evolved to accommodate specific problems and they both work.
                            Andrew.
                            #322854
                            Russell Eberhardt
                              @russelleberhardt48058
                              Posted by jimmy b on 22/10/2017 14:29:04:
                              They are metric in that they are all based on a 6mm diameter 1mm pitch thread. All is explained here. One of the first metric thread standards in the world.
                              Russell
                              #322865
                                People are missing the point off Jimmy's original question: 'WHY'
                                The 'why' is because the Whitworth series screws only had a few smaller than 1/4" and they were all a bit coarse for instrument work.
                                It was decided to have a series of small screw sizes that would suit almost any use. After looking at examples from a around the world a Swiss system was adopted and (supposedly) tweaked a bit.
                                By making each size exactly 0.9 of the previous size everything stays in proportion even though the actual numbers are a bit odd. This didn't matter as they expected them to be made with taps and dies, not screwcutting.
                                Although 0BA is 6mm diameter and 1mm pitch, the British Standard is given in inches rounded to 0.0005" whatever Wikipedia says about the nearest 0.01mm!
                                In practice you will probably only ever need to measure one to check which BA size it is.
                                Despite the passage of time and the appearance of small metric threads, BA is still very useful, especially for modellers who want small, well-intentioned threads.
                                #322866
                                jimmy b
                                  @jimmyb
                                  Thank you for all the input.
                                  I had never before considered threads to such depth. I content myself with a little extra knowledge!
                                  cheers Jim
                                  #322869
                                    Posted by Neil Wyatt on 22/10/2017 16:28:19:
                                    … small, well-intentioned threads.
                                    What a delightful concept !! angel
                                    jimmy b
                                      @jimmyb
                                      Thread problems at work are usually either identifying an unusual thread or simply finding the spec. This is the first time I've ever considered the "why".
                                      NPTF, MJ and UNJ are a few of the specs that tend to trip people up. Identifying threads can also be fun. For example finding the spec for a Morgan wheel nut thread……easy when you know
                                      Jim
                                      #322872
                                      jimmy b
                                        @jimmyb
                                        One of my late shift searches for a thread spec did lead me down a rabbit warren, it was whilst going down a blind alley that I found all about the "German bottle closure thread"…
                                        jim
                                        Edited By jimmy b on 22/10/2017 16:44:19
                                        Edited By jimmy b on 22/10/2017 16:50:28
                                        #322879
                                        richardandtracy
                                          @richardandtracy
                                          How about the plastic bottle thread spec for Coke, Pepsi etc. That is fun when you need to interface with them, but know so little you don't even know what questions to ask. I think I found them as a freebie Indian National Standard, which was/is equivalent to an ISO.
                                          Richard.
                                          #322884
                                            Posted by Andrew Tinsley on 22/10/2017 15:30:41:
                                            Each to his own…
                                            Andrew.
                                            I hope I'm still allowed to criticise the imperfectly logical aspects of Imperial measure? After all there are plenty of examples. Remind me again why there are 14lbs in a Stone?
                                            The current state of the Imperial system is the result of much tidying and tweaking. But it's internally inconsistent. The inconsistencies are historic and nothing can put them right. MKSA also has imperfections but at least it hangs together logically and has room to improve. That's why, taken as a whole, 'metric' is superior.
                                            I'm curious as to why any system of measurement should gather a fan base, become a national icon, or need defending. Engineers and scientists surely understand that measurement is utilitarian, not emotional. The best system is the one that's most useful and straightforward. When I point out that Imperial has more defects than the Metric system, I'm not attacking a religion, personal beliefs, or an individual, its just the truth. I hope we all welcome that!
                                            Equally I'm not offended when the various Metric kludges are pointed out. Bring 'em on, it's all educational. And you never know, they might fix it.
                                            Edited By SillyOldDuffer on 22/10/2017 18:13:14
                                            #322888
                                            thomas oliver 2
                                              @thomasoliver2
                                              10 UNF thread is a few thou bigger than 2 BA and 5mm is a few thou bigger again, but they all have virtually the same tpi.. Thus a 10 UNF screw will fit a slack 2BA thread etc.
                                              #322889
                                              duncan webster 1
                                                @duncanwebster1
                                                Face up to it, Imperial is dying (and the sooner the better). As SoD says, who wants to have to remember the really odd conversion factors such as 550 (ft.lbs/sec to horsepower), 778 (BThU to ft.lbs) etc etc. For most jobs whole numbers of mm are quite good enough, not messing about with 1/64 and 1/32. My son is doing very nicely in real engineering (rather than hobby), and works entirely in SI. Like Andrew Tinsley I'm bi-lingual, but I always preferred to do calculations in SI, much more logical.
                                                #322891
                                                  Posted by SillyOldDuffer on 22/10/2017 18:12:25:
                                                  … Remind me again why there are 14lbs in a Stone?
                                                  Sheep [or more specifically, Wool]
                                                  We adopted the 'Wool Stone' as a standard … and that was 2x 7pounds
                                                  7pounds being the accepted weight of a typical sheep clip.
                                                  Shear genius devil
                                                  Mick B1
                                                    @mickb1
                                                    The answer to that is that people who've made substantial intellectual investment learning idiosyncratic systems as schoolchildren are naturally protective of the effort it cost them.
                                                    Additionally, a great deal of the documentation and drawings for model engineering projects and mechanisms dates from a period when that system was in the ascendant, so it makes sense for model engineers to be fluent in it and conversions between it and the currently-favoured system.
                                                    #322897
                                                    Brian H
                                                      @brianh50089
                                                      As depressingly usual, the topic has drifted off into something quite different. The original question as to why the apparently odd TPI in BA question has been adequately and comprehensively answered, so why the drift off into the sterile argument about metric and Imperial?
