It's that time of year. Despite the late frost I have plenty of apples 'cos I have plenty of trees and I love apple..stewed, baked, pies but strudel is best. This recipe has been played with and adjusted to work for me consistently since last year.
I use tesco filo because it’s the right size sheets. This recipe is for a single strudel, but a pack of filo will make two – just double the recipe. 5 to 6 sheets per.
1.5T Tblsp butter (or vegan spread/marge etc
! Tbsp virgin olive oil
1 tsp cinnamon
!/4 tsp ground nutmeg
1tsp lemon juice
3 Tblsp water
30g brown sugar
65g chopped walnuts
45g raisins
1 cooker and 2 eaters peeled cored and diced.
Preheat oven to 170 fan (or 180 no fan and whatever that is with gas)
If you don't have one of those apple peeling machines get one – cheap and well worth owning – speeds it up no end. For this recipe I prefer a non-collapsing apples
Chuck all the ingredients into a saucepan and heat through without so much cooking it as getting it all mixed up and the juices releasing..may need to add a little more water to stop stuff sticking or burning if you’re impatient.
Once the juices and melted butter/sugar etc develop, then drain in a sieve over a bowl and keep it. If short on juices can stir in some water and melted butter.
Start the filo stack on some baking paper. Each sheet of filo is painted with the saved liquor and given a very light caster or granulated sugar sprinkle (just a pinch) before the next sheet is put on top…repeat for 6 sheets total (or 5 if you only got 10 in the pack. It says 10 sheets but usually you get 12).
In landscape mode you distribute the apple mix on the bottom third about an inch up from the base and 1 inch from each side. That's 2.54cm if using metric apples.
Lift up the lower edge to cover the end of the apple stack, paint with liquor then fold each side up, tidy the corner and let the full length of edge stick down.. paint the new exposed undersides. Carefully roll the whole thing to leave the free (top) edge underneath. Transfer to a baking sheet, paint the top generously with more liquor sprinkle with flaked almonds and more sugar (lightly)
Bake 35mins. When done, sift the top with vanilla icing sugar, leave to cool and try some. Personally I think it's best the next day when the juices soak into the pastry and it’s easier to cut and a little chewy instead of flaky.
Other apple recipes please.
pgk
