The standard advice, when fitting a new lipseal, is not to locate on the same place as the original, but a short distance away, where it will run on a virgin shaft and bed to it.
If this is impossible, then a Speedysleeve makes a good recovery option.
For those unfamiliar, it is a very thin stainless steel sleeve that is punched over the shaft with a dolly, before breaking off the "driving" portion, to leave a new area on which the new lipseal can run.
This is a technique used in industry, so not in the "nasty bodge" category
When installing the new seal, any splines, keyways, or steps should be covered with something like masking tape, to prevent damage to the lip of the seal during installation. If it needs saying, don't touch the lip, either!
Howard.
Edited By Howard Lewis on 06/10/2020 15:00:36
