This item was in a box of oddments that came with a pantograph engraver I bought many years ago, I have never really worked out what its original purpose was, its obviously not engraving related and seems to be some sort of spindle extension.
The coarse thread is 5/8" OD, 11 tpi and the large end shaft is 1" diameter. The other end appears to be made to accept a collet as it has a taper bore (16mm at mouth down to 9.53mm over 17.5mm) and the closing nut has a 45 degree internal taper, the thread about 20.5mm dia is 40 TPI which seems to indicate it was chosen to ensure best accuracy/concentricity when closing the collet. If this was some sort of extension spindle, say for a toolpost grinder then the lack of a precision register at the coarse thread end does not make sense.
The spindle is drilled through and has a removable/adjustable backstop. Its about 11" long overall
Anyone know what this might be off?
Ian P
