My ML7 had Oilite bushings, with no hole drilled through them. From the state of them, it would seem they were factory original. So new ones were installed and left undrilled. One drop of oil in the hole in the casting every time the lathe is used is enough to keep them topped up without making a mess.
I wonder if it makes any difference though? Oil goes in the hole and if undrilled, enters the matrix from the top surface of the bushing and spreads from there throughout the whole. If drilled, it goes through to the gap between shaft and bushing and enters the matrix from there. Possibly more loss of oil out the ends of the gap in the latter method but in practice probably much of a muchness really.
So Occam's Razor and all that good stuff, I opt for the simplest way and don't drill the bushings. This also hass the advantage that swarf particles falling in the oil hole can't get into the moving parts, being held back by the matrix.
Edited By Hopper on 17/07/2018 10:01:50
