Hi David
Hmm How safe are they? not very!
Gloves (That have a grip surface) A full face mask not goggles and protective clothing all a must. Disks can shatter if the tool is misused. (Or just because they feel like it, buy quality known manufacturer disks) hence the need for full face and body protection.
I have set tough Cotton jeans alight, Oily rags go really well too. Sparks can travel several metres.
Use one on steel near your Car windows or any glass and you will find the particles adhered so strongly that removing them will pull a small chip out of the glass, ruining it permanently. Paint will be damaged too.
I have a 230mm 9" and a 120mm both Bosch The 230mm is a beast. The only time I drag the 9inch out is to cut masonry or large pieces of steel too difficult to manoeuvre in the workshop.
And this is where the risk factor really starts to rise. If the structural steel "nips" the blade jamming it the machine will violently try to rip itself from your grip. Make sure the piece you are cutting cannot close the cutline when almost through. or cut from both sides to reduce the effect the work must properly supported.
Another favourite is the blade catching then releasing throwing the 3000+ RPM disk through your leg or any other part of the body that gets in the way. Do not use one near another person.
Ask anyone who works in the building trade or metalworking industry they all will have a story.
A great tool to have when needed. but a Devil in hiding as well.
Edited By John McNamara on 16/08/2015 05:16:31
