allchin 1.5 scale o rings
Home › Forums › Materials › allchin 1.5 scale o rings
  • #412571
    John Vickery
      @johnvickery68803
      Hi Can anyone help in identifying correct size and material grade for glands and piston o rings for use n my allchin 1.5 model. Supplier information would also be appreciated!
      Thanks in advance John.
      #29924
      John Vickery
        @johnvickery68803
        #412587
          Hughes Drew it for Graphite yarn packing so you will have to work out your own hole diameters and depths to get the correct compression on gland O rings and the same with the piston ring grooves. Silicon rings would be best.
          #412599
          Clive Brown 1
            @clivebrown1
            When the repeat construction series was published in ME, starting sometime around 1974, Hughes did provide some details for O-rings for piston and glands. AFAIK, the commercially available drawings are still in the original form however.
            #412605
              Just checked the text and sketches in the book and as Clive says O rings are mentioned and sizes of recess etc given.
            Home › Forums › Materials › Topics
