Alexander Tool and Cutter Grinnder
Home Forums Manual machine tools Alexander Tool and Cutter Grinnder
  • #98970
    D John Maycock
      @djohnmaycock87851
      Hi All,
      I am just coming to the end of a rebuild of one of the above machine which was given to me some time ago, it had stood in the cojner of a workshop for some years but apart from being very dirty it was ok only requireing some paint. an inverter and a new drive belt.
      Included with the tooling etc was a Drill Gringing Jig which for some reason was in a box and dismantled, has anyone out there access to a instruction manual for the Drill Grinding Jig part of this machine as it is not included in the main manual which I have a copy of.
      There is no problem rebuilding the Jig just its use.Regards John.
      D John Maycock
        @djohnmaycock87851
        #99534
        Sub Mandrel
          @submandrel
          Hello John,
          Welcome to the forum. I have no idea of how it works, but I'd be curious to see a picture and one might jog someones's memory or they might have used a similar item.
          D John Maycock
            @djohnmaycock87851
            Hello Neil,
            Thanks for the welcome,I am away from home at the moment so I have found this Deckel Drill Jig on the web, it is the same machine as the Alexander, I will try to post in the album section.
            Thanks John
            #99821
            Sub Mandrel
              @submandrel
              Hi John,
              It looks like you have a generic drill sharpening jig, quality varying from excellent to appaling, I'd guess yours is good, if part of the grinder.
              In short it is set up at the correct cone angle for the drill and the drill point is 'swept' across the grinding wheel.
              I'll try and find the instructions for mine and scan them for you.
              MICHAEL WILLIAMS
                @michaelwilliams41215
                Lots of information here :
                Includes an email address for purchase of full manual .
                Regards ,
                Michael Williams .
