Aircraft General Discussion
Home Forums The Tea Room Aircraft General Discussion
Viewing 25 posts - 901 through 925 (of 2,013 total)
  • #261883
      That looks lovely, Ian
      Thanks for sharing.
      Flying Fifer
        @flyingfifer
        Very strange Brian but at the time I was told it was the other way round. The original aircraft were handbuilt but the new wings were as you say built to drawing (which were probably "metric" whilst the originals were imperial !! ).
        Still have fond memories of my day away in a Nimrod especially the looks on the faces ot the 2 guys in the conning tower of that Russkie sub which we dropped in on. Absolute magic !
        Alan
        #261885
          Posted by Ian S C on 19/10/2016 13:26:01:
          Here's the next Mossie into the hanger for fitting out over the next few months.
          With thanks to Slackie/RNZAF Pro Boards
          Ian S C
          Edited By Ian S C on 19/10/2016 14:04:17
          Amazing what you can do with MDF!
          #261888
          Martin Kyte
            @martinkyte99762
            BAe built us a cradle to lift the radar mod tank through the door of the AEW verson of Nimrod. It had to be modified as I would not fit through the doors of all the aircraft even though it was to the aircraft drawings and within the tolerances. It was always said that Britain built aircraft and America manufactured them. It never really mattered if you left the airframe crew to just get on with it. The made bits to fit what was in front of them not to fit a set of drawings.
            regards Martin
            #261899
            JA
              @ja
              Posted by Flying Fifer on 19/10/2016 15:18:08:
              I guess the question is "who knows more about the aeroplane?", the design and development engineers (in other words the manufacturer) or the air crew?
              A basic philosophical engineering question – do you build the prototype using designers' sketches and produce the manufacturing drawings afterwards or do all the drawings first and then make the prototype?
              JA
              #261900
                Posted by JA on 19/10/2016 17:43:54:
                JA
                The people who pay the bills will also know a lot about the aeroplane. And having three different viewpoints on the same object leads to truly spectacular disagreements!
                #261904
                martin perman 1
                  @martinperman1
                  Did that not happen in the space race not that long ago, the uk built something in metric to fit a rocket built in inches.
                  Martin P
                  #261911
                  JA
                    @ja
                    Posted by martin perman on 19/10/2016 18:10:19:
                    Martin P
                    Many jokes have been told and cartoons drawn about the mix-up between SI and Imperial units. Occasionally there are serious incidents – The Boeing 777 had its fuel capacity measured and displayed in kg (we should ignore that kg is a unit of mass) while their earlier airliners displayed lbs. The inevitable happened soon after its introduction when a crew got muddled up and under fuelled their aircraft. The result was that the engines stopped somewhere over the Canadian prairies and the 777 dead sticked onto a disused airfield. Fortunately no one was hurt particularly as the airfield was being used for a motor race meeting.
                    JA
                    #261912
                      Posted by JA on 19/10/2016 19:23:20:
                      Martin P
                      JA
                      I think this example is famous for the pilot being both seriously disciplined for not confirming before take-off that he had sufficient fuel AND then getting an award for his extraordinary performance landing the aircraft after running out of fuel!
                      #261925
                      Brian H
                        @brianh50089
                        Just goes to show that we should stick with Imperial to avoid this sort of thing!
                        #261934
                        Carl Wilson 4
                          @carlwilson4
                          The situation Re the Nimrod fuselage and the MRA4 wing was down to the new wing being built to the letter of the original drawings, whereas the aircraft were built to the spirit of the drawings.
                          When I worked at Nmsu (aka “Findhorn Strip Club”) in the early to mid 90s, the first thing I learned was not to manufacture anything slavishly to the drawings. We had all the drawings on a big fiche reader that could be printed out. All the drill sizes were either fractional inches or number/ letter sizes. Having metric drills the trusty Zeus book was well thumbed. The aircraft technicians friend.
                          I soon learned to make the part then take the dimensions and fits off the aircraft itself.
                          I was also at Abingdon in the early 90s and I stripped out the Aews and then cut them up. A soul destroying job.
                          Carl.
                          #261953
                          John Olsen
                            @johnolsen79199
                            That 777 in Canada is generally referred to as the Gimli glider, Gimli being the disused airforce base it landed at. There were two runways, one of which was open for general aviation traffic, and the other was in use as a race track. The pilot chose the wrong one, fortunately without any dire consequences. The aircraft was actually over Lake Winnipeg when everything stopped happening. Apparently the pilot had experience with gliders, so was well aware of how to find the optimum glide speed from the performance information available to him. If he had not chosen the right speed they would most likely have ditched in the lake. As the Hudson incident showed, this is certainly possible, put would have lead to a loss of hull and quite a lot of risk to the passengers.
                            There is quite a full article on wikipedia: **LINK**
                            Bill Pudney
                              @billpudney37759
                              When I was a ships drafty, one of the major parts of the job was to do an "As Built" set of drawings. This involved going over the whole ship/submarine and checking, things like bulkhead penetrations and pipe/a/c system runs to see how much they deviated from the drawings. It was a right royal p.i.t.a.
                              cheers
                              Bill
                              #261988
                              Gordon W
                                @gordonw
                                I was a draffy at De Haviland back in the early 60s. I remember doing drawings to convert the Comet galley into a fuel tank space. Might not have been done of course. All drawings were in inches, no feet . smaller divisions in decimals of an inch. So metric inch if you like.
                                #261990
                                  Shiaparelli…
                                  …oops.
                                  #261998
                                  JA
                                    @ja
                                    Posted by Neil Wyatt on 20/10/2016 10:52:12:
                                    Shiaparelli…
                                    …oops.
                                    Dead stick landing. Did it bounce?
                                    JA
                                    #262001
                                      Posted by JA on 20/10/2016 11:33:39:
                                      Shiaparelli…
                                      …oops.
                                      JA
                                      Not a problem apparently. "This is typical for a test," said Prof Jan Woerner, Esa's director general.
                                      #262037
                                      JA
                                        @ja
                                        Posted by John Olsen on 20/10/2016 01:25:31:
                                        ………. If he had not chosen the right speed they would most likely have ditched in the lake. As the Hudson incident showed, this is certainly possible, put would have lead to a loss of hull and quite a lot of risk to the passengers.
                                        If one has to make a forced landing, land on land. It is hard, the aircraft bounces, perhaps, and then runs along the ground gradually loosing speed even without the undercarriage. You just have to pray that the aircraft does not hit anything and there is no fire. If you ditch in water usually the nose digs into the water, the wings are ripped off and the body goes tail over head. Very, very few ditchings are successful. A study on the subject published around 2000 suggested that less than ten ditchings of large aircraft since 1945 had been at all successful. This is the main reason why the Hudson River ditching is so remarkable. I believe there were two successful ditchings of Nimrods in the early 2000s, one was at an air show (Edinburgh?).
                                        JA
                                        #262049
                                        Martin Connelly
                                          @martinconnelly55370
                                          And yet the instructions to the Red Arrows when flying over London is that if there is a problem ditch in the Thames.
                                          Martin
                                          #262052
                                          Martin Kyte
                                            @martinkyte99762
                                            "And yet the instructions to the Red Arrows when flying over London is that if there is a problem ditch in the Thames.
                                            Martin"
                                            Sort of depends if you are attempting to save the pilots or the civilian population doesn't it?
                                            regards Martin
                                            #262053
                                            Brian H
                                              @brianh50089
                                              A firm I worked for had the job of repairing the avionics on one of the ditched Nimrods. Needless to say most of the items and wiring were scrapped because of the effects of being in salt water.
                                              Presumably the airframe was refurbished.
                                              #262059
                                              Cornish Jack
                                                @cornishjack
                                                While the Hudson river ditching rightly reflected great credit on Sully, little is said about the invaluable help given by the Airbus f.b.w. system, which ensured that the wings remained level at the stall. Dropping one wingtip in first will really spoil your day in that scenario!!
                                                rgds
                                                Bill
                                                #262079
                                                Carl Wilson 4
                                                  @carlwilson4
                                                  Posted by Brian Hutchings on 20/10/2016 15:31:35:
                                                  It wasn't.
                                                  Carl.
                                                  #262080
                                                  Carl Wilson 4
                                                    @carlwilson4
                                                    Posted by Martin Kyte on 20/10/2016 15:30:36:
                                                    Martin"
                                                    regards Martin
                                                    They have a zero – zero seat so once they know it's going in the water they can eject.
                                                    #262084
                                                    Martin Connelly
                                                      The thing about a Hawk aircraft hitting the Thames is that it is likely to catch the water and cartwheel into what may be a crowded tourist area. Aiming for the river may not be the best way to minimise casualties.
                                                      Martin
