Aircraft General Discussion
Home › Forums › The Tea Room › Aircraft General Discussion
Viewing 25 posts - 376 through 400 (of 2,013 total)
  • #195235
    Metalmuncher
      @metalmuncher
      Just saw the Vulcan Pass over the house enroute from Ipswich to Norwich, great sight and sound. Keith.
      #195237
      martin perman 1
        @martinperman1
        Not far up the road from Andrew and myself is RAF Alconbury where the upgraded U2 the TR1 was based for many years, my Father worked for W Vintens, makers of photo reconnaissance camera's and pods, and he used to go to work on the stand at the Farnborough shows and always came home with loads of black and white photographs of various aircraft he could acquire for me, most I still have.
        #195279
        Cyril Bonnett
          @cyrilbonnett24790
          Flying down the A1 on my Honda 750 and too fast really, you're only young once, I was overtaken by a huge shadow, turned out to be a Vulcan flying so low that I thought it was going to land on the road. Just mind blowing.
          Edited By Cyril Bonnett on 28/06/2015 20:20:43
          #195294
          Nicholas Farr
            @nicholasfarr14254
            Hi, I saw the Vulcan this afternoon as it flew right past my son and his partner's garden at a not too greater height. He lives near the New Costessey area of Norwich. As it past it then swept slightly to the right with a little roll and as it was climbing, got a view of the wing underneath and over most of the top.
            Regards Nick.
            #195309
            Mark P.
              @markp
              Now that's a gearbox! Bristol radial engine.
              Mark P.
              #195310
                Posted by Mark P. on 29/06/2015 09:16:51:
                Even John Stevenson might struggle to replace that lot with Timing Belts.
                NJH
                  @njh
                  Easy to see why radial engines went out of fashion!
                  Norman
                  #195318
                  Hopper
                    @hopper
                    Setting the timing marks on that radial must have been quite the job.
                    #195320
                    Danny M2Z
                      @dannym2z
                      The talk of Vulcans reminded me of when I was a young digger snorkeling in the Med just off the end of the runway at RAF Akrotiri (Cyprus).
                      The water started to vibrate and everything went dark. Thought it was an earthquake.
                      Shot to the surface to look up the tailpipes of a Vulcan that had just cleared the runway.
                      I remember that it seemed to spew out a lot of black smoke – maybe they left the choke in?
                      * Danny M *
                      #195321
                      JA
                        @ja
                        Posted by NJH on 29/06/2015 09:33:41:
                        Norman
                        The big aircraft piston engine just became incredibly complex. The Bristol gearbox is just an example. RR post Griffin engines such as the sleeve valve Eagle engine were just as complex. The jet engine, which gave more power/thrust and did not need a propeller, was much simpler. For a short time.
                        Don't even consider the starting procedure for something like a Bristol Hercules. With a jet engine it was just one button (however if the jet engine was German, if it lit successfully you did not use the "throttle" once the engine was running at maximum thrust).
                        JA
                        Edited By JA on 29/06/2015 11:12:39
                        #195328
                        Cornish Jack
                          @cornishjack
                          Re. the Bristol gearbox, spent a couple of years sitting between 4 of Bristol's Centauri as they dragged the constant speed, variable noise Bev along the airways. Both the engines and the aircraft were remarkable in their separate ways – the sleeve valves in the Centaurus and the design concept of the Beverley. Heath Robinson would have viewed both with joy!!
                          rgds
                          Bill
                          #195332
                          Ian S C
                            @iansc
                            Back in the 1960s had a close up of a Pratt & Whitney R-4360 engine on a Operation Deep Freeze Globe Master, these were nick named corn cob engines, a 4 row, 28 cylinder engine that could produce 4300 hp at 1,11hp/lb, a major job just cleaning the spark plugs, all 56 of them, can't remember how many trips to the ice they did before they did a top overhaul (wasn't many), all done at the Deep Freeze Hanger, Harewood/ now Christchurch International Airport.
                            Ian S C
                            #195334
                            NJH
                              @njh
                              Ah the Beverly!!
                              I recall as a lad ( it is a very long time ago!) cycling across with a mate to RAF Abingdon and scrounging a flight on a Beverly. We were accommodated in the cockpit where we sat on a box ( containing the autopilot ?) whilst the pilot did circuits and bumps.
                              On other occasions there were flights in the body of the plane when it was setup for parachutists. Not very comfortable, very noisy, and probably an incentive to the parachutists to jump out!
                              Norman
                              #195589
                              Ady1
                                @ady1
                                A form of aircraft, this guy is a cross between batman and a dive bomber
                                Made me feel queasy just watching it, he still has to get enough height after the stunt to open his chute
                                Edited By Ady1 on 02/07/2015 14:16:14
                                #195689
                                Cornish Jack
                                  @cornishjack
                                  Norman
                                  Your cockpit seat was, actually, the battery box, containing a bunch of NiFe cells (huge) to cope with the Bev's electrical system, flaps , anti-ice etc. Next to it (rearwards) was a floor to ceiling metal caged distribution panel referred to as the Hammond Organ. The bottom panels of this would have indentations over the locations of the BTH units – the result of flying boots being forcefully applied to get the electrics on-line!! Aft of the flight deck was another compartment which had hatches to allow access to the rear of the engines via internal wing walkways. (Theoretically possible in-flight but not if you wanted to retain your sanity!!) Finally, a rearward facing hole was the entry to the 'Dog Kennel' within which was the hand pump and selector cock for in-flight transfer of oil to the engines (104 gallons available) This activity was required on most flights and was a bit of a chore for those of us who smoked!! Cold-soaked oil after a few hours at 8000' is pretty 'treacly'sad
                                  rgds
                                  Bill
                                  Edited By Cornish Jack on 03/07/2015 16:27:13
                                  #195703
                                  NJH
                                    @njh
                                    Hi Bill
                                    Thanks that is interesting information.
                                    I must say that flights in the Beverly were not my best aviation experiences but they did pave the way for my future interests. Once I had grown up a bit I joined the local gliding club where I learned to fly and, in time, owned with two friends, a rather lovely all aluminium sailplane. Much fun and excitement. Later I moved and a gliding club is now too far away. Never mind I have set up a nice workshop here and pootle about to my hearts content!
                                    Norman
                                    Edited By NJH on 03/07/2015 20:46:31
                                    #195705
                                    Mike Poole
                                      @mikepoole82104
                                      I used to live under the approach to Abingdon and well remember the Beverly, one year a Phantom at the Abingdon airshow managed to lift the roofs of the bungalows in Wootton, I think the RAF fixed every crack in every home in Wootton that year.
                                      #195709
                                      Ady1
                                        @ady1
                                        What does it take to restore a World War Two Spitfire?
                                        #195710
                                        Sam Stones
                                          @samstones42903
                                          Never having been close and personal with a four engine Beverly I have seen quite a few raising clouds of dust as they landed and shoved the props into reverse thrust.
                                          It was around `57-`58, during my NS stint under canvas alongside the east/west runway of RAF Nicosia, when something like fourteen landed one evening. From the other side of the airfield, there hardly seemed sufficient space on the apron to park them all.
                                          A day or so later, they took off again seemingly empty judging from their angle and rate of climb. Being so large and from my vantage point, they seemed to hang in the air as they gradually disappeared into the distance.
                                          Sam
                                          #195712
                                          V8Eng
                                            @v8eng
                                            Posted by Ady1 on 03/07/2015 22:39:16:
                                            What a colossal achievement!
                                            Edited By V8Eng on 04/07/2015 00:06:01
                                            #195724
                                            martin perman 1
                                              @martinperman1
                                              On my way home yesterday from working in Saffron Walden I passed by Duxford, on the flight line was a P51D Mustang, one I've never seen before, and what looked like a Spitfire but it was un painted, unfortunately I wasnt able to see more apart from a T6 Harvard joining the circuit.
                                              Martin P
                                              Edited By martin perman on 04/07/2015 10:01:38
                                              #195727
                                              Anonymous
                                                Ah, that makes sense; I heard (and saw) an aircraft doing aerobatics over the house yesterday afternoon. Definitely wasn't a Spitfire, so I identified it as a Mustang. I see a lot of Spitfires, but not many Mustangs, so good to see it. The engine wasn't like the 'bag of nails about to stop' sound you get from a UK built Merlin either. All I need is a lottery win to put one on the shopping list. thumbs up
                                                I think the Harvard does passenger flights, as I see it pretty regularly. It also seems to use Bourn airfield as a base for some flights.
                                                #195731
                                                JA
                                                  @ja
                                                  'Bag of nails about to stop'.
                                                  I was told as a spotty youth about 50 years ago about Spitfires engines: The Merlin was smooth and sounded good, the Griffin sounded truly awful. If it was the opposite the engine was about to fail. The RR owned Griffon engine Spitfire, seen and heard many times, always sound as if it was about to fail.
                                                  JA
                                                  #195757
                                                  martin perman 1
                                                    @martinperman1
                                                    Gentlemen,
                                                    Vulcan XH558 is displaying at the Shuttleworth collection tomorrow and I'm going to be 60 miles away, bugger, Andy and Rik Shaw keep your eyes peeled.
                                                    Martin P
                                                    #195765
                                                    martin perman 1
                                                      @martinperman1
                                                      Had a Fieseler Storch trundle over this afternoon on its way to, I assume, Shuttleworth for tomorrow.
                                                      Martin P
