Posted by old mart on 30/06/2021 18:53:32:
If you have a digital meter, set it to 20 megohms and test that black plastic, it is very unlikely to be a conducting grade, but, being black, it could be antistatic, there is a remote possibility.
Edited By old mart on 30/06/2021 18:54:5
An Urban Legend that…
If there are any carbon chains in that sort of coloured material, they never are in contact and never form a continuity path in the material below the hundreds of meg-ohms region. Any finger grime on the material will conduct more than the material innards!
The same applies to Anti-static bags ( for electronic components, etc) – the pink, black and silver bags that are common in the field have a spec to which compliance is required – clean with alcohol and then distilled water, warm to 35deg C for 1 hour, and resistivity must be such that less than 1nanoamp will flow with 1000VDC applied to two 1cm contacts spaced 20mm apart…
So the possibility of conduction in black perspex is not even remote.. – @ 5V you could use a bit of Tomato Box…
Joe
