ACME tap
ACME tap
Home Forums General Questions ACME tap
  • #259640
    richard ellis 1
      @richardellis1
      Hi
      I am after a 5/8 inch 4tpi tap.ACME
      It is to be used to cut a thread into some Delrin.Need to make a new half-nut for a Legacy wood lathe. At a push a short bit of leadscrew would do.I could macle it up to cut the thread
      Thanks
      richard ellis 1
        @richardellis1
        5/8 inch 4 TPI ACME taper tap
        #259867
        not done it yet
          @notdoneityet
          An alternative is to cast some delrin (m.p. about 170 Celsius) around your lead screw. An apparent easy fix for a full lead screw nut, but might be a bit more of a challenge for a half nut.
          Acme threaded rod is available from suppliers, if you wish to make your own tapping tool.
          Hope this helps.
