I, want to make a mobile access platform to use for cutting my hedges and reaching my gutters [single story house ]
I am considering using semi bright box tubing to make up four frames, each frame being welded up as a separate unit,so that it could be taken apart for storage,and bolted together as required.
The size I have in mind is something about 8 or ten feet long x 2 ft wide x 4 ft high. I think I may need struts to brace it on the outer side.
Having looked up to see what is available,I found two sizes which might suit :
50 x 25 x1.5 or x 2mm
40 x 40 x 1.5 or x 2 mm
Anything bigger would be too difficult to move even though the unit will be fitted with wheels at one end and handles at the other.
Any advice, suggestions,comments,good,bad,or indifferent,welcome !
It it is considered to be a No-No,feel free to say so,it,s just that ladders and I ,do not see eye-eye anymore.
Thanks for any ideas,
Larry.
