A most unusual metal
Home Forums General Questions A most unusual metal
Viewing 13 posts - 26 through 38 (of 38 total)
  • #317502
    Martin Kyte
      @martinkyte99762
      As I said, Zinc.
      Martin
        I read the first page and was going to say 'surely it's just zinc'… but I won't bother now.
        Martin Kyte
          @martinkyte99762
          "Could I just say it's zinc?".
          . . . . . . "No sorry there isn't time"
          (on loan from Monty Python)
          #317537
          Ian P
            @ianp
            I never thought in might be plain Zinc. Not that I know much about Zinc other than its used in galvanising but I thought it was very soft whereas this is hard and brittle (it is a cast part though).
            Oddly in some previous replies Zinc is not perceived as being easily solderable.
            Again odd is the fact that it is plated, as its is easily soldered and never ever going to be seen, why bother to plate it.
            Ian P
            #317544
            Martin Kyte
              @martinkyte99762
              Have a look at this data sheet
              It's plated to look nice and shiny. Zinc is used for sacrificial anodes on canal craft and is similar to aluminium regarding softness, gets quite malleable if heated to 200 deg C and solders easily as you discovered.
              regards Martin
              #317546
              Ian P
                @ianp
                Posted by Martin Kyte on 18/09/2017 16:19:24:
                regards Martin
                Well I never!
                I've been involved with electronics for too long and yet never been aware that straight Zinc was used for mechanical parts like these. This one is obviously Zinc so wood and trees come to mind.
                Thanks
                IanP
                #317555
                  We used to have a zinc can opener, much bulkier than a pressed steel one.
                  I think it's in one of my scrap boxes… hmm I may have a use for it…
                  #317625
                  vintagengineer
                    @vintagengineer
                    This might be the same crap that SU carburettors are made of. I tried TIG welding one and got large quantities of blue smoke, a sign of zinc.
                    Vintage car ali castings are full of zinc due to it being cheaper than ali and you can add it to molten ali to bulk it out
                    Posted by Phil Whitley on 17/09/2017 13:00:43:
                    Probably Zamac, or some such zinc/aluminium alloy used for die casting, commonly known as "monkey metal", because of its fondness for falling to pieces after a couple of years, or when stressed beyond its very limited limits! Its great advantage is that it is ridiculously CHEAP!laugh
                    #317638
                      Martin,
                      I bow to your wisdom, but I remain absolutely astonished that die-cast Zinc [whether pure, or an alloy] can provide sufficient structural integrity for the shell in question:
                      [quote] The casting is what I would call finely detailed, its mostly about 0.30mm thick yet where the two edges of the clamshell meet there is a male/female stepped joint. [/quote]
                      P.S. … This is the best statement I can find on the matter of wall-thickness:
                      Wall Thickness
                      Zinc alloys have excellent casting properties, which means that thin walled cross-sections are possible. Zinc diecastings are often cast to a thickness of 1mm, with thinner sections possible depending on the flow of material to that area. Thin walled casting has a superior strength to weight ratio, thus strong and light zinc diecastings can be designed using the minimum of metal. This also improves the production rate and lowers cost.
                      **LINK** http://www.pmsdiecasting.co.uk/technical/for-designers/
                      #317649
                      Bazyle
                        @bazyle
                        Gosh this is going on and on. When corgi and dinky and matchbox cars started being made out of plastic all the muck metal had to be used for something wink
                        #317656
                          Fair comment, Bazyle
                          … But 0.3mm wall thickness is very impressive.
                          Martin Kyte
                            @martinkyte99762
                            Posted by Neil Wyatt on 18/09/2017 17:15:52:
                            I've got a tin can opener !
                            The other interesting thing about zinc is it screams when you bend it cold.
                            regards Martin
                            #317676
                            Russell Eberhardt
                              @russelleberhardt48058
                              Posted by Martin Kyte on 19/09/2017 09:13:59:
                              So do I laugh
                              Russell
