A Certain Age
A Certain Age
Home › Forums › General Questions › A Certain Age
Viewing 25 posts - 1 through 25 (of 138 total)
  • #27811
    Ray Lyons
      @raylyons29267
      #512015
      Ray Lyons
        @raylyons29267
        At the beginning of the year, I decided to give my lathe a thorough "spring clean". Using the dustpan and brush, I cleared all the swarf, and then, taking the suds drain hose out of the tank, putting it into a bucket, used an engine degreaser to to wash down. After that, I cleaned with rags and then polishing cloths to get everything bright and shiny. A final task was to spray over with a light oil to keep it looking good.
        Then came that very hot summer with lockdown. Confined my activity to a couple of hours in the garden with a break in the hottest part of the day when I used a fan indoors to keep cool..
        After lockdown, a project came up when the lathe was brought into use again. It didn't take long to fill the tray up with swarf but unfortunately, the suds stopped working. Thinking that over the hot weather (and many years of use) the level in the tank had evaporated, I mixed up another gallon and we were back in business but it again stopped working after a couple of hours. I decided that the tank was possibly bunged up with crud and starving the pump. Pulling the tank and pump out, I discovered the bucket behind the lathe with the suds drain hose in it and now full of contaminated cutting oil.
        Just had my annual quote for my car insurance. Wonder why it has gone up?.
        #512017
        Nick Clarke 3
          @nickclarke3
          While being too polite to comment on your episode, I have just installed the replacement dishwasher in the kitchen. tested it on rinse as I was supposed to and the display comes up FF together every light possible, all flashing.
          Thinks – I suppose I need to turn the water back on!
          As to my actual age I am still young enough to fall over and not yet old enough to 'have a fall'
          #512032
          Roger Best
            @rogerbest89007
            laughlaugh
            I have has Covid-brain all summer to add to my advancing age. I would tell you all the funny anecdotes but I have forgotten them.
            #512033
            colin brannigan
              @colinbrannigan54160
              I was cleaning the lounge on Thursday and needed the dustpan and brush from the kitchen by the time I got to the kitchen I couldn't remember what I came to the kitchen for, walked back to the lounge and saw the little pile of dirt on the floor and it dawned on me, I just laughed it off, no point worrying about it, it's just old age.
              Colin
              #512037
              AJW
                @ajw
                Came home from holiday a few years ago and one of the first jobs is usually fire up the boiler for some hot water – it didn't work
                Boilers in the loft so up I go possibly thinking it needs resetting, it didn't. Scratching my head I now start dismantling it to find out why it won't light and while I'm inside thought I'd give the heat exchanger a brush and hoover up. Checked the ignition unit etc.
                Then I had a memory cell spring to life – I'd turned the gas supply off!
                Worked a treat after that.
                Alan
                #512067
                Brian Sweeting 2
                  @briansweeting2
                  It's not just me then, thank goodness.
                  The number of times recently when I've walked out 9f the kitchen thinking "I'll look that up on the computer". Then to sit there looking at the blank search engine screen thinking "what was it again?"
                  #512070
                  ChrisH
                    @chrish
                    Oh Don't! I'm forever walking off to fetch something, getting there and then thinking what did I come for and having to walk back again to try and remember.
                    And the "I'll look that up on the computer later" trick, and then getting to the computer and forgetting what I was supposed to be looking up – I can string that one out for days and days and still not look it up. Whatever it was. I forget.
                    Not to mention using a tool and then putting it down and 30 seconds later thinking where did I put that and being completely unable to find the tool anywhere, and I haven't even moved out the shed. Mind you, I put that down to the little people in my shed borrowing things……………… they usually leave what they have borrowed in the exact spot where I left it a couple of days later……….
                    Isn't this old age great….
                    Chris
                    #512071
                    Ady1
                      @ady1
                      We tell each other what we want to look up later on the 'puter
                      When we get home we've both forgotten what it was
                      #512087
                      Nigel Bennett
                        @nigelbennett69913
                        We have a system where if we're just about to fall asleep at night, one of us will say, "Oh, yes, remind me to mow the kittens in the morning" or whatever, and one of us will reach out and chuck a coaster from the bedside cabinet on to the floor.
                        Then in the morning, we can both spend a happy hour or two wondering what the blazes it was that the coaster was supposed to remind us to do…
                        #512105
                        Mike Hurley
                          @mikehurley60381
                          Lets not even mention car keys and glasses!
                          #512108
                          Peter G. Shaw
                            @peterg-shaw75338
                            It's not only down to age. Now I know some might disagree with what I'm about to say, and will use phrases like "so what's different", but a few weeks ago one of the oncologists decided I was aneamic. This was duly reported to my GP who put me on ferrous fumarate, initially 3 x 210mg per day. It eventually became apparent that I was unable to tolerate that dosage, and eventually came off it completely, but one thing that did develop was what I called "brain fog", ie memory & mental failure. I have, this am just come back from seeing the podiatrist and I have absolutely no memory of being there 8 weeks ago, indeed I suggested that it might have been last year, but my diary doesn't lie. Fortunately, memory and the other mental functions have recovered, but it's frightening to see what can happen.
                            Peter G. Shaw
                            #512122
                            Hopper
                              @hopper
                              Posted by Peter G. Shaw on 07/12/2020 10:27:51:
                              Peter G. Shaw
                              Ferrous fumarate? A good dose of cast iron swarf is what you need. laugh
                              Yes the brain fog/memory thing can be a challenge. Shed work does seem to help, I have found.
                              #512147
                              Howard Lewis
                                @howardlewis46836
                                Ah! Many of us are reaching the age where we think about the hereafter.
                                i.e. What am I here after?
                                #512149
                                Morty
                                  @morty
                                  Hi Everyone!
                                  I have been thinking about getting one these Alexa thingies, so I can tell it what I was going to do so I can ask it!!!!
                                  Then again, I would probably forget to ask it, or even tell it in the first place!indecision
                                  Take care (of Your Mind!). Cheers, Pete
                                  #512152
                                  MK_Chris
                                    @mk_chris
                                    Howard. There is always the teenage version : if we can remember !
                                    "If you're not here after what I am here after then you'll be here after I've gone !"
                                    But what on earth was it that I was after ?
                                    Chris.
                                    #512154
                                    Steviegtr
                                      @steviegtr
                                      On the back of the Kitchen door we have a large cork board with lots of pins. Write everything down & pin it. Or it will never happen.
                                      Steve.
                                      #512171
                                      Anthony Knights
                                        @anthonyknights16741
                                        The quote at the top of the December page of my calender (on which In write all my hospital appointments) reads-"No man is ever old enough to Know Better"
                                        #512176
                                        Georgineer
                                          @georgineer
                                          Posted by Steviegtr on 07/12/2020 12:50:00:
                                          Steve.
                                          That only works if you can remember it long enough to write it down!
                                          George B.
                                          #512179
                                          john halfpenny
                                            @johnhalfpenny52803
                                            I have a small hardback notebook in which is placed all manner of info, some of which was hard to acquire, and may be difficult to do so again. Eg, vee belt sizes, bearing part numbers; taps and dies in my posession and wanted; critical dimensions of lathe and mill (in case I see a bargain, but not sure if it will fit); brief instructions for numerous tasks such as converting a car from pos to neg earth, or identifying whether a 12v coil is for a ballasted system or not; dimensions of my workshop and garage; etc. I use it, and add to it, almost every week.
                                            It fits in madam's handbag, so will usually be available if I don't remember it myself. I also no longer move workshop things to a new storage location – having several times looked in the old place, and not remembered the new.
                                            #512180
                                            Speedy Builder5
                                              @speedybuilder5
                                              Oh how depressing, BUT what do we do with all those tools, models etc. Yes, sure they have a value, but probably your missus or whatever sure doesn't want the stuff, and its a problem getting rid of it. Call the workshop clearance people round and get a 1/4 of its second hand value. Why not support the younger generation who can't afford all this stuff. So, before we fade away, and visits to the shed reduce why not encourage young un's to join our clubs, loan them a model to look after all the while they are at the club. Equip some of these clubs with the superb tools we have collected.
                                              Just an idea chaps!
                                              #512337
                                              Kiwi Bloke
                                                @kiwibloke62605
                                                Retitle the thread 'Uncertain Age'?
                                                #512382
                                                larry phelan 1
                                                  @larryphelan1
                                                  Had to go for a checkup myself last week, to see if I am more senile this year than last.
                                                  Last year tests took 1 hour, including waiting time
                                                  This year total time 35 mins, so far so good !
                                                  Doc says, "Dont know why they send you down here, nothing much wrong with your mind "
                                                  I said, "Perhaps just to keep you busy ?"
                                                  She replied, "No need for that, let me tell you, it,s a very common problem with people of advanced years "
                                                  Note-not OLD PEOPLE but those of "Advanced years". I like that term, makes me feel better.
                                                  Just wondering that at 82, when do I cease being of "Advanced years" and become "OLD" ?
                                                  I,m just wondering that at 82 when do I cease being of "Advanced years" and become " OLD"
                                                  Scary !!!
                                                  #512431
                                                  Peter G. Shaw
                                                    @peterg-shaw75338
                                                    Larry,
                                                    In my case, it was my last birthday, when I reached 77!
                                                    Incidently, I've also had the "We are supposed to check on people like you to see if your mind is OK. I can tell you're OK." That was about 5 years ago.
                                                    Peter G. Shaw
                                                    #512449
                                                    Howard Lewis
                                                      @howardlewis46836
                                                      There are compensations for being "mature", of "advanced years" or whatever is the popular wording not to cause offence.
                                                      Am now waiting to be summoned for my first Covid shot! Wife will have to wait another month to jump the queue!
                                                      In my book, you are as old as you feel. Sadly it varies from day to day and time to time.
                                                      Walking to and from town, the 4 mile round trip sometimes needs a short sit down on the way home. (Watching the wildlife on the river, and admiring the flora and scenery" is the excuse. Can't be too long or the journey exceeds the 50 minute trip allowance )
                                                      Now, where was I? What am I here after?
                                                      Howard.
