Reply To: Any views on using Fairy Liquid in a concrete mix
Home Forums The Tea Room Any views on using Fairy Liquid in a concrete mix Reply To: Any views on using Fairy Liquid in a concrete mix
#546912
not done it yet
    @notdoneityet
    Enough to form bubbles will very much increase the workability of the mix. Not good for the strength as concrete relies on good compaction for maximum strength development.
    Masonry cement, for brick-laying, etc incorporated an air entraining additive to improve the workability and use of mortars where ultimate strength is not required (mortar should be weaker than the bricks/blocks). It is far better to replace brickwork pointing, if building movement causes cracks, than replacing bricks🙂 .
    Far better to use the correct additives, approved for the job, than washing-up liquid.
    I once had to visit a concrete user who had found low strength concrete (cube testing) results which had been used in concrete pilings. The bulk cement had been delivered by a tanker previously used for washing powder product/ingredient. The concrete pilings actually smelt of ammonia (which presumably retarded the setting of the concrete). I don’t know if later strength tests were accepted or if the pilings had to be replaced. An expensive exercise.
    The concrete supplier knew the cause before I arrived – he already had cement samples and cube test results – and I knew of the outside contractor that delivered the dodgy load to the depot – before it was transferred to a company tanker prior to final delivery to the ready-mixed concrete site cement silo. Those pilings might still be propping up something in Linford (now part of Milton Keynes).
    Edited By not done it yet on 24/05/2021 20:23:03
