Reply To: Thornton Miniature Gear Cutters
Home Forums General Questions Thornton Miniature Gear Cutters Reply To: Thornton Miniature Gear Cutters
#236304
Ajohnw
    @ajohnw51620
    Posted by Michael Walters on 25/04/2016 14:33:44:
    What's happened to them? I'm pretty sure their website is down.
    Also, i've tried searching the forum for information about them but to no avail.
    They sell quite expensive gear cutters but as far as i know they are one of the few who still make 7MM bore small gear cutters.
    As an aside, has anyone read the "workshop practice series: gears and gear cutting" by Ivan Law? i've heard that in the book there is detail on how to make your own silver steel involute gear cutters, given how expensive the thornton ones seem (£99 a piece)
    Michael W
    Yes it's in number 17 of the workshop practice series. It's also about on the web usually missing mounting the buttons on a 5 degree slope to gain front clearance. A bit of back rake can be ground on the top as well. Or if the buttons are mounted flat around 5 degrees of back rake but make sure the cutting edge is very slightly below centre as there is no front clearance. These are then used to make the cutter. Simplest is a circular blank that then's gashed to make one cutting edge or by offsetting a blank in a jig several cutting edges.
    When it comes to cycloids as used in clocks there are a number of standards. Like most things they are approximations so that cutters can be made. There is also one aimed at use with lantern pinions. These are I strongly suspect the main gain with cycloids as pinions with differing tooth counts need specific cutters.
    Some links
    and making the cutters
    A search for David Creed Making Clock Wheel and Pinion Cutters will also find that.
