Reply To: New Lathe
Reply To: New Lathe
Home Forums Beginners questions New Lathe Reply To: New Lathe
#133702
Dave Harding 1
    @daveharding1
    Thanks for the replies.
    The taper is narrower at the tail stock and increases as you get nearer the chuck
    I initially used a piece of 1/2" aluminium bar 4" long secured in the chuck I centred the cutter then faced the work piece no dimple so I then used the top slide to make a 1" long straight cut. I did this in small passes then removed the piece and miked it there was a definite taper.
    I tried again with a piece of 5/8" bar stock 4" long secured I the chuck faced it then started to turn the bar stock I ended up with a taper a smaller diameter at the tail stock and larger at the chuck its not a huge amount but as I bought the lathe to make small machine parts that have to be a exact measurement if I can not sort this then the lathe is no use to me.
    I have had it a month the speed control knob proved to be useless after two days I replaced it with one from a needle valve we use at work.
    Adjusting the cross slide is a pain to morrow I am going to modify it so it is more user friendly.
    None of the verniers on any of the adjusting wheely things are accurate.
    Up to now I am not very happy with this lathe. I have lots of projects I want to get under way but there is no way I would tackle any of them with this lathe.
    Home Forums Beginners questions New Lathe Topics
