Centre Finder Query
Centre Finder Query
Home Forums Beginners questions Centre Finder Query
  • #334894
    Martin King 2
      @martinking2
      Hi All,
      I have several centre finders, two of which I use all the time from choice and feel quite happy with using them.
      However, I cannot for the life of me understand how one is suposed to use the 'needle point' accessory that some of them have.
      I have tried to get it in a centre punched hole and managed to break two of them! angry
      Clearly I am doing something wrong here and wish to be put right even at the expense of letting all know just how dozy I am at times!
      Cheers, Martin
      #9029
      Martin King 2
        @martinking2
        #334903
        Tony Pratt 1
          @tonypratt1
          Get the needle point to run concentric & then use to pick up scribed lines, no need to centre punch the lines beforehand.
          Tony
          #334906
          I.M. OUTAHERE
            @i-m-outahere
            Make sure you use a piece of metal or a small rule to set it true – don't use ya finger !
            #334913
            Martin King 2
              @martinking2
              Posted by XD 351 on 02/01/2018 12:25:56:
              Point taken! wink
              Martin
              #334914
              Martin King 2
                @martinking2
                Posted by Tony Pratt 1 on 02/01/2018 12:03:46:
                Tony
                By 'pick up scribed lines' do you mean just by eye? What about a centre popped point?
                Cheers, Martin
                #334958
                Jim Nic
                  @jimnic
                  I find accurately picking up scribed marking easy enough especially using a magnifying glass. However, unless you are already at the correct location dropping the needle point into a centre pop mark can move the needle and require re-centering it before you can have another go.
                  Jim
                  #334963
                  I.M. OUTAHERE
                    @i-m-outahere
                    You bring the tip of the needle down very close to the line or centre punch mark and line it up by eye , with a mill the work is usually clamped down and not free floating like on a drill press where you can wiggle it around as you lower the centre / spotting drill down into the centre punch mark.
                    Not really a super precision item but with practice you can get within a few thousandths easily enough ( waiting now for someone to come along and state they get within 0.0001 – Good for them !) but if more accuracy is needed you would edge find then use X&Y co ordinates to locate the drill or use toolmakers buttons .
                    Where they are really useful is locating a centre punch mark down in a cavity or slot .
                    Ian.
                    #334964
                    Tony Pratt 1
                      @tonypratt1
                      Posted by Martin King 2 on 02/01/2018 13:05:55:
                      Tony
                      Cheers, Martin
                      Yes by eye, there is no point centre popping by eye then picking up the centre pop with the needle point again by eye, just pick up the lines with the point.
                      Tony
                      #334967
                        It doesn't go in the hole, you true it up with the edge of a ruler (I use the back of my fingernail) and then line the crossed lines, centre pop etc. up with it by eye.
                          Just in case it's not obvious from what's been said already.
                          Assuming the target is the crossing point of two lines scribed at right angles to each other:
                          • Stabilise the needle so the point spins on the spindle's axis without wobbling
                          • Drop the needle as close as possible to the work without touching it
                          • Adjust the lighting to make the lines stand out
                          • With your head at the front align the needle point with the forward/back scribed line.
                          • Move head to the side to align the needle on the right/left scribed line.
                          • A magnifying glass helps
                          David George 1
                            @davidgeorge1
                            I have a piece of plasticene which has a dressmaking pin embedded in it sat on the side of the mill I just stick it to the end of the cutter start the mill at a slow speed and using my nail set the point true and that never fails to pick up lines or points. I have been using this method for at least 40 years.
                            David
                            #335002
                            Phil P
                              @philp
                              This YouTube video shows how to use a wiggler.
                              https://www.google.co.uk/search?q=how+to+use+a+wobbler&oq=how+to+use+a+wobbler&aqs=chrome..69i57j0l4.4314j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
                              Phil
                              #335015
                              Paul Lousick
                                @paullousick59116
                                Getting the needle point of the centre finder to run concentric & centre by eye ?????
                                Instead I just use the shank of a small drill (or any small round bar). Mount it in the chuck and file the end to a point. Then centre by eye with a magnifying glass. Just as accurate, as long as your drill chuck is concentric.
                                Paul.
                                #335038
                                David Taylor
                                  @davidtaylor63402
                                  I'm glad someone asked that, I have one and had no idea what to do with that part! dont know
                                  I usually do what Paul said, just line up the centre pop with a drill point or pointed rod.
                                  David.
                                  #335096
                                  Martin King 2
                                    @martinking2
                                    Thanks guys, much appreciated!
                                    Martin
                                    #335111
                                    Howi
                                      @howi
                                      I usually put a centre pop,then use the pointer on the centre finder gently lowered onto the centre pop, then raised out of the centre pop, if the two are not concentric the pointer will describe a circular path when raised ( because it is off centre), by adjusting the x and y axis and gently raising or lowering the pointer into the centre pop you can get the pointer centred over the centre pop. Very quick and easy to do, long so fed to describe.
