Cleaning machines and workshop
Home Forums Beginners questions Cleaning machines and workshop
  • #123238
    Chris Heapy
      @chrisheapy71135
      This is not something most worry about – unless like me you are subject to endless grief should swarf find its way onto the living room carpet!
      However, another complication is the use of flood coolant and the resultant pile of soggy swarf, and how to dispose of it. I had reverted to the jam-jar of cutting fluid and paintbrush method which wasn't too difficult to clean up with an ordinary domestic vacuum cleaner, albeit the small capacity bags needed frequent changing (at no little cost), but having reinstated my flood coolant on the mill the small domestic cleaner simply can't cut it any more.
      So today I took delivery of a larger wet and dry vacuum cleaner which I thought was pretty good value at around £100 ( **LINK** ) and it seems to do the job nicely. No more worry about a dust bag getting soggy or swarf being sucked into the motor, this thing is designed for sucking up wet stuff. Much more powerful at sucking swarf out of crevices too – provided you don't let it suck up stray drills and taps etc., at the same time. The 30Ltr capacity is also a bonus. I wish I had it a couple days ago when I accidentally released a half gallon of coolant onto the workshop floor!
      Chris
      #6764
      Chris Heapy
        @chrisheapy71135
        #123240
          Beware of leaving the inside damp making the filter soggy then sucking up regular dust or worst plaster. Ideally keep it dry inside. The 'wet and dry' is the marketing dream. Try to take off the filter regularly and reverse blow it with the airline (outside of course).
          #123241
          michael howarth 1
            @michaelhowarth1
            I have got a similar model and it works very well considering the amount of oily filth that gets sucked into it. Only one problem has arisen and that is the corrugations on the vacuum tube can trap oily muck and swarf and on occasions gets partially blocked. Vigorous bending and twisting (the tube, not me) whilst the motor is running usually clears it but the time is fast approaching when I shall need a new tube. Who sells them?
            Mick
            #123242
            Ian S C
              @iansc
              You can make a system using an ordenary vacuum, And a 12gallon drum, make a wooden top for the drum with two holes, one takes the hose from the vacuum cleaner, the other is for another hose. On the under side of the lidput a vertical partion that will hang down 6" or 8" in the drumand make up some sort of filter over the suction hole, anything that gets through that filter will be caught in the cleaners own bag, but 99% of the workshop rubbish will end up in the drum. Secure the lid with say 1/4" / 6 mm bolts fixed to the drum, with wing nuts to hold it together, 2 bolts seems enough. Ian S C
              #123243
              Peter G. Shaw
                @peterg-shaw75338
                Bazyle,
                I to have a "wet and dry" cleaner, this time by VAX. The "wet" part refers to the ability by swopping some parts for the cleaner to be used for jobs such as shampooing a carpet, sucking water out of a drain, sucking up spills. The "dry" part refers to its main ability as a dry(ish) dirt remover. I say "dry(ish)" because within reason it will suck up damp stuff such as swarf wet from whatever cutting lubricant I have been used. Now ok, in this mode it does cause a stain on the cotton dust collector bag.
                As such, it does work remarkably well in both "wet" and "dry" modes. Hence certainly in my case, this not a marketing dream.
                Usual disclaimer as a very satisfied user of a Vax Power 4000 cleaner bought around 20 years ago, and which has been used mainly in the workshop, but to clean carpets, to suck up water during & after a flood, to empty an external stop cock hole of water, and to suck the water of some new concrete foundations prior to building on them.
                As regards the comment about the p[ipe getting blocked, in my case this is entirely due to me using a pattern part rather than an original after I broke the original. Prior to that, I never had a blockage.
                Peter G. Shaw
                Edited By Peter G. Shaw on 27/06/2013 15:24:42
                #123256
                Another JohnS
                  @anotherjohns
                  Chris;
                  How does the suds work in the house? Any smell? I've got my shop in my house, and that's both good and bad.
                  I've changed liquid for air – and the jury is still out. I'm using air jets to cool my CNC milling machine tooling, and I think it works ok. It also blows away the swarf. It's noisy, though!
                  My shopvac is used for cleaning up the shavings; long coils, of course, I pick up by other means, as they'll plug the vacuum hose quickly.
                  Another JohnS – http://cnc-for-model-engineers.blogspot.com has a little bit on my air cooling of the KX1 mill that I have.
                  #123264
                  Chris Heapy
                    @chrisheapy71135
                    No smell from the suds I use, some are better than others though (low odour should be on the container) and it should also have an inhibitor to stop fungal growths. I find suds gives a easier cutting and better finish, cooling isn't really a problem for me.
                    Chris
                    #123266
                    Sub Mandrel
                      @submandrel
                      I have an Earlex (branded as Wickes) wet'n'dry vac bought 2002 when we moved in to help with major DIY and still going strong. The house has got through several cleaners including two Dysons in the same period.
                      Mark P.
                        @markp
                        I to have an Earlex wet'n'dry vac had it quite a few years and has been mercifully abused in that time but still going without complaint!
                        Mark P.
                        #123281
                        Alan .204
                          @alan-204
                          I've had two Earlax wet & dry as I'm a plumber its the best bit of kit I have, you do not want to know what goes through my hovers even I try to forget, in the workshop I have a cheap £40 wet & dry hover only ever use the sponge filter and cable tie it to the hover works great, the first Earlax only bit the dust because of the switch, the workshop hover gets everything through it including a lot of coolant and some cutting oil, when its a third full or so it's tipped in to a builders bucket through cloth (curtain) left to drain then tipped back on the machine, the coolant that goes through tends to keep the hose clean.
                          Alan.
                          #123294
                          John McNamara
                            @johnmcnamara74883
                            I have a Vax
                            I picked it up at a trash N Treasure market for a few dollars….. It works very well. Not sure how old it is? it is Yellow plastic with a black plastic bin. more than 10 years I guess. It is always beside the lathe, I use it every day.
                            If you do use a Wet N Dry Vac they can get quite stinky if you do not empty the cutting fluid and other muck out after use.
                            Chris Heapy
                              @chrisheapy71135
                              I dimly recall having a Vax at some point years ago, my only memory of it was it sounded like a Jumbo Jet starting up! One thing about the Ryobi – it is reasonbly quiet in operation. For the stinky thing, there are a variety of chmicals you can add to kill the smell.
                              Chris
                              #123307
                              John McNamara
                                @johnmcnamara74883
                                Yes Chris the Vax is powerful it will empty a bucket of water in a few seconds. not bad for a small machine.
                                #123321
                                Peter G. Shaw
                                  @peterg-shaw75338
                                  My VAX is 1200W, and like John, once it gets going on water it is really fast. In carpet cleaning mode, under full power if can be almost impossible to push the cleaning head over the wet carpet. I assume this why it has a variable speed control.
                                  Noise-wise, it is no more noisy than the household 2000W Hoover cleaner, and may be less noisy, but suction wise it's definitely better.
                                  The machine is actually supposed to be used with disposable paper bags, but the cotton bag is an alternative and considerably cheaper as it is washable. It isn't as good as the paper bags in that some fine dust does get through, but for what I use it for, so what?
                                  Smells? Haven't noticed any – I assume they get lost in all the other lovely workshop smells.
                                  Peter G. Shaw
                                  #123600
                                  John Coates
                                    @johncoates48577
                                    Aldi have got one out this Thursday for £60 and a 3 year warranty
                                    Andyf
                                      @andyf
                                      The link goes to Lidl, rather than Aldi. Looks a good machine, though sadly a bit big for my limited space.
                                      Andy
                                      #123618
                                      John Coates
                                        @johncoates48577
                                        Posted by Andyf on 02/07/2013 00:21:07:
                                        D'oh !!!!!!
                                        Yeah the email was from Lidl. Bit of brain fade there crook
                                        #123625
                                        Chris Heapy
                                          @chrisheapy71135
                                          The Lidl offering is probably good quality (Aldi/Lidl stuff usually is) although it is not as powerful as the Ryobi (vacuum is 190mbar as opposed to 235mbar on the Ryobi), and the hose looks to be smaller diameter. Still, worth considering at the price.
                                          Chris
                                          #123627
                                          Swarf, Mostly!
                                            @swarfmostly
                                            Just a thought:
                                            Has anyone tried centrifuging their swarf to separate the cutting fluid (you know, like the 'big boys' do)?
                                            Best regards,
                                            Swarf, Mostly!
