EN16T
EN16T
Home › Forums › Beginners questions › EN16T
  • #122911
    Steve Withnell
      @stevewithnell34426
      I understand that the "T" means treated. Does that mean fully annealed ready to machine or fully hardened or somewhere in between?
      The piece I have is flippin' hard stuff.
      Steve
      #6761
      Steve Withnell
        @stevewithnell34426
        #122913
        David Jupp
          @davidjupp51506
          T = 850MPa – 1000MPa UltimateTensile Strength or 55 Tsi to 65 Tsi in old money.
          So no not fully annealed, but not terribly hard either
          #122931
          David Jupp
            @davidjupp51506
            See table of BS970 Temper condition codes asbout half way down page on this site **LINK**
            #122971
            mick
              @mick65121
              Hi. Steve.
              Are you still playing about with that V8 of yours? EN16T should machine reasonably well using standard tooling and machineary, I always understood the "T" to stand for tempered ie in its soft state. If you have problems check with the supplier, as they may have supplied you with a bar end, so you may have something like EN24T which is a different kettle of fish. I ordered a 6'' billet of EN1A a while back, but the swarf came away like chewing gum, it wasn't until I supplied photos of it being turned that the supplier put his hand up and replaced it with the right grade, so its worth getting back to the stock holder and making a bit of a fuss.
              Cheers. Mick
