Buying descision
Buying descision
Home › Forums › Beginners questions › Buying descision
  • #120442
    Frank
      @frank
      Reached a cross roads in my Budget planning for my new workshop.
      Given that I've got £1,000 to spend on machinery, I'm undecided between buying a lathe and milling machine or spend the lot just on a lathe?
      Bearing in mind that I'm a complete beginner and that I want to have a go at small engines/models, I assumed that buying a lathe and mill would be the way to go.
      However, based on User recommendations, I do like the look of the Sieg C4 lathe (which blows the budget on its own). I would like the lathe to have powered feeds, which I'm not sure the Chester Conquest lathe has got.
      Opinions/advice please?
      #6722
      Frank
        @frank
        #120452
        SteveW
          @stevew54046
          Spend it on a lathe a bit bigger than you think you need, keep a little to buy any tooling, taps etc (say £150) and start saving for a mill. Steve W
          #120454
            If you do go for just a lathe then make sure you can fit a vertical slide to it as this will allow you to use the lathe for light milling operations, Even if there is not a specific one for your chosen machine it is often possible to fit a decent Myford one, thats how I built the traction engine in my avitar – Emco lathe and Myford slide.
            Most of the small lathes are likely to have a powered longditudinal feed but its not until you get to something around the size of the Warco 250VF that you will get power cross feed.
            J
            #120469
            GaryM
              @garym
              Frank,
              Arc Eurotrade have a special offer on the C6 at the moment including some of the accessories you'll inevitably need:
              Gary
              Edited By Gary Marland on 22/05/2013 20:47:21
              #120474
                All the imports come with those accessories these days. It's like electric windows on cars.
                I think I'd prefer an AUD for that money.
                Accedemic anyway as Frank should have stapled his wallet shut for 3 months while he learns more.
                #120476
                Ady1
                  @ady1
                  Save yourself a HUGE amount of cash and hold out for a Drummond M series
                  Then munch lots of metal and have 800 quid for all the other bits you'll need
                  Try and get one with a 3 and 4 jaw chucks
                  gl
                  Edited By Ady1 on 23/05/2013 01:55:22
                  #120491
                  Durhambuilder
                    @durhambuilder
                    this doesn't appear to be a bad buy, the basic lathe without accessories is nearly £3k new, with the stand and accesories probably nearer £4k worth….
                    http://www.lathes.co.uk/advertphoto/130410ceriani/
                    or for a little extra work and searching for the missing bits, an emco compact 10.
                    http://www.thetoolbox.org.uk/late_arrivals/metalworking2.html
                    Edited By Durhambuilder on 23/05/2013 09:21:38
                    #120525
                    Robbo
                      @robbo
                      There's an Emco Compact 8 advertised on homeworkshop.org.uk which may suit.  Price £450
                      Contact John on 07847 621456, but be quick.
                      Located in Walsall, so not far away
                      Phil
                      Edited By Robbo on 24/05/2013 09:51:27
