Help with Hobbymat Md65 lathe
Home › Forums › Beginners questions › Help with Hobbymat Md65 lathe
Viewing 3 posts - 1 through 3 (of 3 total)
  • #91546
    Martin Neubert
      @martinneubert28247
      Hi all
      Newbie question.
      I have a md65 lathe, but the motor is not that good anymore.
      I would like to put in a new one, but which one ?
      The corrent motor is a 230v ac 250w 2840 rpm.
      i want to switch the motor i order to make it with adjustable speed and rewerse.
      unfortunaly the £ isnt to many, so a cheap solution would be aprisiatet
      Any suggestions ?
      Best Regards
      Martin (Denmark)
      #6168
      Martin Neubert
        @martinneubert28247
        #124641
        Raine Surakka
          @rainesurakka84509
          Hi Martin ! I have the hobbymat md65 Lathe and there is 250w 3-phase motor and Omron 3G3JV -series 0.4kW Variable Frequensy Driver.
          Packet is Good and it is daily use in my "home-shop-machining" Little motor does NOT have power enought and it IS killing noise when Power is needed, when i try take bigger chip from Axle.
          I recommedent You get 0.6kW or Bigger motor and 1—- 2.2kw VFD Whit that motor.
          BTW!! I must get installed my Mill to Run. i do have 2.2Kw Siemens Micro master and old slicing machine motor what is 3-phase (propably i Think so)
          Sincerly : Raine S From Finland
