Query on Jim Whetren’s toolrest
Home Forums Beginners questions Query on Jim Whetren’s toolrest
Viewing 3 posts - 1 through 3 (of 3 total)
  • #4953
    Geoff Ellis
      @geoffellis82435
      #48288
      Geoff Ellis
        @geoffellis82435
        I was very interested in Jim Whetren”s article on modifying the George Thomas quick change hand turning tool rest, as I have just bought George Thomas” book to attempt to make a tool rest for use with clock work.
        I have a Seig C3 mini lathe, and Jim”s article seems to be aimed more at  these sorts of mini lathes (what you can see of the lathe in his pictures certainly looks familiar) than the Myford Geo Thomas usually has in mind, However, the bed centre gap in his article is 61mm, and on the C3 I make the gap only 25mm. Am I measuring the right gap or has he a much bigger machine? Can anyone advise if this tool post will still work okay with only half the gap, or should I look at another way of securing/locking it?
        I am a newcomer to all this, and Jim”s version of the tool rest seemed to be much easier for me to tackle but it looks like I will have to modify it quite a bit.
        (Jim”s article was numbered 4991. I found it via Google, but had a bit of trouble finding it from within the MEW website itself).
        Geoff
        #48289
        Jim Whetren
          @jimwhetren72358
          Hello Geoff,
          If you scroll down the Home Page and click on More Latest Articles, this article is on page 6.
          The rest was made for a Prazimat lathe – 180 x 450 mm. However, I can’t see any reason why the tapered clamp should not still work if the parts were much narrower. It just means using smaller diameter screws and springs.
          Although this isn’t the only way to clamp, I was attracted to one twist of the lever for both jobs, as per Mr Thomas.
          Jim
