Myford Lever Action Collet Chuck
Home › Forums › Beginners questions › Myford Lever Action Collet Chuck
  • #45954
    John C
      @johnc47954
      Hello All,
      I acquired a  Myford Lever Action Collet Chuck which wouldn’t move! I managed to get it apart to find that the body key had been deformed out of its slot.  I got this out and cleaned up and the chuck now seems to work. But – there was only one ball bearing in the sleeve, and that seems too small for the holes. Also, the sleeve will now slide out of the body if the chuck is held nose up.
      So – how many ball bearings should there be, and what size? And how is the
      chuck held together – if it is.
      The chuck has two keyways in the body – is there a reason for this?
      Thanks in advance for any info. Photos posted in case someone else is having
      similar trouble!
      John C
        @johnc47954
        #49486
        Anthony Spencer 1
          @anthonyspencer1
          Hi John
          I have just stripped my Myford Collet Chuck and there should be * ball bearing (one in each hole)
          #120427
          Richard Brickwood
            @richardbrickwood17062
            I too have just acquired a Myford lever action collet chuck and it works OK BUT I am having difficulty getting it tight enough on 1/8' rod to hold it whilst cutting thread. The knurled closer has no hole (and is hardened so not easy to drill one) so can only assume it relies upon hand tightening: I've used a large wrench but am concerned about damaging the knurles. Any ideas anyone?
            Richard Brickwood
