clocking in
clocking in
  • #41143
    John Scott 13
      @johnscott13
      John Scott 13
        @johnscott13
        I'm new to the forum .
        Member of a local model engineering club .
        FWIW I have a Colchester Bantam lathe and a Rong Fu ( like a Warco ) round column mill which I have fitted with a simple CNC, retaining the handwheels – so as to have either NC or manual control.
        #564258
        Brian H
          @brianh50089
          Hello John and welcome. I (and others on here) would like more details of your CNC conversion please.
          Brian
          #564260
          Harry Wilkes
            @harrywilkes58467
            Welcome to the forum
            H
            #564307
            David George 1
              @davidgeorge1
              Hi John welcome to the forum. The CNC upgrade sounds interesting can you give us a picture or two and how do you disengage the motors when you use handwheels and vice a versa.
              David
              #564440
              John Scott 13
                @johnscott13
                David, Everybody,
                thank-you for the interest in the RF CNC project.
                I've shamelessly copied a design from YouTube driving the axes leaving the handwheels in place. With the stepper drivers switched on – you can't move them by hand. Drivers off – you feel the steppers cogging over giving slight resistance to motion. The X&Y leadscrews are replaced with ballscrews which would rotate under axial load without that resistance. I'm told that the steppers probably generate backEMF which may not be good for drivers , i haven't had problems.
                 photos  are probably self-explanatory
                The Z acts on the quill. The original quill rack-and-pinion mechanism gives more backlash than i'm happy with.
                Controller is GRBL running on Arduino – works very reliably – I am impressed.
                Arduino step-and-direction output goes to hefty drivers bought with the stepper motors from cnc4you – works fine – photo shows all the bits – subsequently moved to proper enclosure-
                In use for 5 years for shape-simple and shape-complex machining.
                hope that's helpful,
                johns
                Edited By John Scott 13 on 27/09/2021 12:39:06
                #564446
                Brian H
                  @brianh50089
                  Hello John, the best thing that you can do with photos is to create an album for each subject.
                  Albums can be found in thegreen and black banners at the top of this page. Don't quote me but I think that the green banner is for personal albums and the black one will show you ather members albums.
                  Brian
                  #564457
                  Brian H
                    @brianh50089
                    Hello John, your pictures are showing fine on the forum.
                    Brian
