Myford ML7 not running true and spirals
Home Forums Help and Assistance! (Offered or Wanted) Myford ML7 not running true and spirals
  • #375962
    Ian m 1
      @ianm1
      Hi,
      it seems that my chuck is not running true on an old Myford ML7 lathe. I know nowt about the lathe and it has been 40 years since I did an apprenticeship of 1 year and so I'm quite rusty myself. Is there any adjustment if so where, if not what is likely to be worn and can it be replaced?
      Also, I get spirals along anything I turn. what should the chuck be spinning at?
      To me it seems slow. Is there anywhere I can send cutting bits to, to be sharpened, doing it myself is beyond me.
      thank you in advance
      Ian m 1
      #33285
      Ian m 1
        @ianm1
        #375995
          Hi Ian,
          Sorry to hear of the problems.
          How have you tested the chuck and how bad is the error?
          When you say spirals, is this just a light surface pattern or is the tool effectively cutting a 'screw thread' in the work? How fast are you running the lathe and are you using power feed – it may be set up for screwcutting rather than fine feed.
          Grinding tools is fairly easy, a simple knife tool will do most things.
          You may find it cheaper to buy pre-ground HSS tools – most styles are designed for easy resharpening, or you could try inserted carbide tools.
            Take Chuck off and clean the thread and register collar area and remove burrs might help.
            #376010
            Redsetter
              @redsetter
              Ian, I doubt if your problems are serious- it sounds as though you need someone to give you a hand to get started. Where are you located? I'm sure someone on here who is within reach would be happy to help.
              #376026
              Ian m 1
                @ianm1
                Neil,
                I would not say light spirals, bit worse then that. Not using power feed. I donit know how fast chuck spins but it seems slow, i will need to check motor plate.
                Anything in the jaws of the chuck can be seen not to run true.
                Hopper, Ill try that. Thankyou
                Redsetter, there is a "Mens shed" group, I'll try them but "Southampton" is where I am
                As a teenager my work as a 1st year apprentice was ok.
                Ian M 1
                #376032
                Mike Bondarczuk
                  @mikebondarczuk27171
                  Hi Ian,
                  I am also in Southampton and it does sound as if the work piece is turning too slowly and your feed rate along the work is too fast, thereby causing the spirals.
                  Drop me a line via the private messages and let me know where you are and perhaps I can help you out, as I also have a Myford 7, as well as other lathes.
                  #376108
                  Grizzly bear
                    @grizzlybear
                    Ian,
                    Slow speed, is your lathe in back gear?
                    Run-out, are the chuck jaws clean/ swarf free, this is inside the chuck.
                    Good luck, keep us up to date.
                    Bear..
                    #376109
                      Posted by Ian m 1 on 15/10/2018 10:46:41:
                      How much is that, a few thou would be par for the coarse on a 3-jaw, on the other hand if it is more like 1/16" them check that the jaws are in the right slot, both should be numbered 1, 2 & 3
                      #376117
                      Ian m 1
                        @ianm1
                        Posted by Grizzly bear on 15/10/2018 19:52:07:
                        Ian,
                        Bear..
                        is my lathe in what? if you mean reverse, no otherwise sorry i dont know what back gear is
                        Ian
                        #376118
                        Ian m 1
                          @ianm1
                          Posted by Mike Bondarczuk on 15/10/2018 11:57:45:
                          Hi Ian,
                          thank you kind of you, where are you?
                          Ian
                          #376119
                          Ian m 1
                            @ianm1
                            Posted by JasonB on 15/10/2018 19:58:57:
                            dont know how much out of true, would need to get a gauge and measure. i have a feeling it's a 4 jaw chuck.
                            even feeding by hand i expect to get a better finish
                            the advice so far gives me things to check next weekend, thank you.
                            ian
                            #376122
                            Grizzly bear
                              @grizzlybear
                              Ian,
                              "is my lathe in what? if you mean reverse, no otherwise sorry i dont know what back gear"
                              Not reverse, but reduction, you have to physically put it into , or out of low gear (Back gear).
                              Check with the lever adjacent to the chuck.
                              Bear..
                              #376123
                                Posted by Ian m 1 on 15/10/2018 20:37:14:
                                ian
                                That might be the problem Ian. Most 4-jaw chucks aren't self-centring. If it's the usual type of 4-jaw each jaw has to be adjusted independently. They're good for holding work like square bar and also for positioning round bar very accurately. But they don't do it automatically. Various ways of setting them up, most usually with a DTI, like this youtube example.
                                  Get yourself a copy of L H Sparey’s book The Amateur’s Lathe and start from basics. Also Ian Bradley’s book on the Myford 7 Series will help you understand back gear and other basic operating stuff.
                                  #376158
                                  Michael Bird 1
                                    @michaelbird1
                                    When I had spirals it turned out to be the headstock bearing caps were loose on my ML7. I tighten them up and the spirals went away.
                                    #376161
                                    V8Eng
                                      @v8eng
                                      Posted by Ian m 1 on 15/10/2018 20:32:27:
                                      Ian,
                                      Ian
                                      I have put a link here to an explanation of “back gear” which reduces spindle speed considerably, hope this might be some help with that particular question🙂
                                      Edited By V8Eng on 16/10/2018 09:46:02
                                      #376246
                                      Grizzly bear
                                        @grizzlybear
                                        V8Eng,
                                        Thank you for adding the 'Link'. Re: Back gear.
                                        Bear..
                                        #376338
                                        Ian m 1
                                          @ianm1
                                          Thank you V8Eng for the link. I will check tomorrow to see how the lathe is set up. Even reading the explanation I had to read it more then once.
                                          I will also start actioning the advice given, I have been away on holiday and back home today.
                                          I would like the quality of my work to improve but my work will not progress past simple stuff as this is all i need.
                                          Ian M 1
                                          #376398
                                          V8Eng
                                            @v8eng
                                            Posted by Ian m 1 on 17/10/2018 14:57:45:
                                            Ian M 1
                                            In my link the “Back Gear” operating lever is at the bottom right hand corner of picture 1. It is shown in the normal running condition – if the lever is in the ‘up’ position that means the back gear is engagaged and will be giving a 6 to 1 speed reduction, I do not recall ever using back gear personally so cannot be of further help on that one.
                                            Please do head all the warnings about the possibility of damaging gears etc!
                                            I wish you luck with sorting your problem out and hope you enjoy using the ML7, I certainly like mine having owned it for a few decades.
                                            I agree with Hoppers suggested books, also an ML7 manual would probably prove useful if you do not already have one.
                                            Edited By V8Eng on 17/10/2018 20:35:56
                                            Edited By V8Eng on 17/10/2018 20:57:48
                                            #376435
                                              I think you also have to disengage the 'bull gear'. Back gear always requires two things – engaging the low ratio gear train and disengaging the normal drive.
                                              Ian m 1
                                                @ianm1
                                                an update, not really good news
                                                The lathe is not running in back gear and the back plate on the motor shows the RPM to be 1425.
                                                I have a Myford manual that i downloaded from the internet, so i'll go and check how to remove the chuck which is a 4 jaw chuck and all 4 jaws tighten at once. They are not independently tightened.
                                                I'll try cleaning the thread
                                                what is the cross bed feed measured in? looks like it goes to 100.  The chuck is worse out of true between jaws 3 and 4.  Going by the gauge on the cross bed feed, the chuck is  6/100   or 3/50 out of true.  I have "measured" between the face of the chuck and the chuck key holes.  Is this withing tolarence
                                                Ian M 1
                                                Edited By Ian m 1 on 19/10/2018 11:41:17
                                                Edited By Ian m 1 on 19/10/2018 11:55:28
