Has anyone played with Galinstan?
Home Forums Materials Has anyone played with Galinstan?
  • #390146
      Galinstan is an alloy of gallium, indium and tin used as a non-toxic mercury substitute.
      Although there is a commercial alloy that melts at -11C (supposedly with a couple of other trace ingredients) the standard eutectic alloy melts at 9C.
      I can imagine various uses of this, rather like woods metal, etc. but also the potential for unusual projects such as making tilt sensors or electric motors that work by dipping wires into a pool of molten metal at room temperature without the health risks of using mercury.
      Has anyone had experience of this alloy?
        Andrew Tinsley
          @andrewtinsley63637
          Hello Neil,
          I (and others) have used Indium Gallium eutectic as a means of making good contact with electrical probes on doped semiconductor material It basically reduces contact resistance to very low levels.
          Andrew.
          #390150
          Ian P
            @ianp
            I can see uses as you suggest for electrical contact purposes but it would be rather expensive as a Woods metal substitute (assuming it was available). I could only find very small quantities when I searched just now but no one seems to have any stock.
            Ian P
            #390158
              Uses I have found include finishing optical flats and its lack of surface tension seems to be as desirable as other properties.
              The cheapest way to get a (very) small amount seems to be buying a thermometer from Spain!
            Home Forums Materials Topics
