Identity of static engine kit
Home Forums General Questions Identity of static engine kit
  • #594790
    Clive Steer
      @clivesteer55943
      I've been given, what appears to be, a kit of castings and materials to make a static engine. Unfortunately there were no drawings or document identifying the model name or supplier. I've done a quick search on the internet and found it is not a Stuart model so I'm hoping someone may be able me identify it.
      #28674
      Clive Steer
        @clivesteer55943
        #594798
        paul rushmer
          @paulrushmer83015
          Hi Clive
          Looks like Tina from GLR to me, If you look on there web site there are pictures of the individual castings.
          Hope this helps Paul
          #594814
          Clive Steer
            @clivesteer55943
            Hi Paul
            Many thanks and you are spot on with the model. I went onto their site and looked at the casting which bear the same numbers as those on the parts I have. I'm not a steam model builder so I'll probably sell the kit on to someone more likely to complete it in the manner it deserves.
            #594966
            Bob Unitt 1
              @bobunitt1
              Clive, have you got the bed (cast aluminium, about 12.5" by 5", 1/2" thick) and/or the flywheel (cast iron, 6" diameter, 6 spokes) ? you look to have the rest of it.
              #594972
              Clive Steer
                @clivesteer55943
                Unfortunately the bed plate and flywheel were not in the box. However I do have some 15mm thick Ali plate which although will need some chopping our won't need facing.
                CS.
                #594978
                Bob Unitt 1
                  @bobunitt1
                  They're available separately from GLR, totalling about £70. Unfortunately I've recently bought a set myself, or I'd have been interested in making you an offer sad
