Shim stock
Shim stock
Home › Forums › General Questions › Shim stock
  • #28373
    PipesandStuff
      @pipesandstuff
      #565346
      PipesandStuff
        @pipesandstuff
        Hello chaps. Well it is moving forward and I appreciate the help and the replys I have gotten here. I have decided not to use the old original 3 phase motor and just get a new 1 phase. But have changed the bearings and refurbished the old motor in case I decide to sell it. Next job is to make the shims to the headstock. Could these be made out of soda cans? Or do I need to buy thin brass shets?img_20210926_181516.jpg
        #565348
        Thor 🇳🇴
          @thor
          I wouldn't use aluminium (soda cans) for shimming, brass or steel would be better, something like this.
          Thor
          #565349
          PipesandStuff
            @pipesandstuff
            Posted by Thor 🇳🇴 on 03/10/2021 14:21:25:
            Thor
            Do you know anywhere in Norway that sells these kinds of shims stock Thor?
            #565350
            Thor 🇳🇴
              @thor
              The closest I have found is:
              ***Link*** (may not be your size)
              You may have to order from abroad.
              Thor
              #565358
              noel shelley
                @noelshelley55608
                Some drinks cans are steel and then there are oil cans ! Noel
                #565364
                  The problem with Aluminium shims made from a can is the metal slowly deforms under pressure: the alloy is too soft for a permanent shim.
                  Mild steel is better but still relatively soft. Steel cans are made from dead mild-steel, which is a fair bit softer than mild steel. Extruded drink cans are always made from a soft metal, and although convenient, they're not ideal for shimming. I use aluminium to shim my 4-way tool post and occasionally put new in due to it flattening in use.
                    I have no idea whether you would find a local supplier, Tonny … but this type of material is ideal for shimming split bearings : **LINK**
                    http://www.shimpack.com/shimlammetals.html
                    Dave S
                      @daves59043
                      I have used razor blades for small shim stock – the double edge type, not the ones moulded into plastic.
                      Oldiron
                        @oldiron
                        Another source of good shims are feeler gauges. Dirt cheap and available every where.
                        regards
                        #565379
                        PipesandStuff
                          @pipesandstuff
                          I too thought about feeler gauges, but they are not wide enough. Need to be something like this. screenshot_20211003_160807_com.ebay.mobile.jpg
                          #565380
                          Mike Crossfield
                            @mikecrossfield92481
                            I have used material salvaged from old feeler gauge sets to make shims in the past when I didn’t have the right size shim stock to hand.
                            edit. Didn’t type fast enough……..
                            Edited By Mike Crossfield on 03/10/2021 16:40:00
                            #565386
                              If you can't obtain laminated shim stock, the alternative is to buy shim steel..
                              Stubs sell it in UK in thicknesses from 0.0015" (0.038 mm) up wards to about 0.0102 (0.254 mm )
                              HTH
                              #565392
                              Trevor Drabble 1
                                @trevordrabble1
                                Tonny , l have limited stocks of both brass and steel shim in different thicknesses. If you could please list the actual quantities , sizes and thicknesses you require I'll do what l can to help . Trevor.
                                #565403
                                PipesandStuff
                                  @pipesandstuff
                                  Found a shop that sells thin sheets of brass. Just bought some and will give that a go. Thanks for the replys!
