5/8″ BSP compression nut
Home › Forums › General Questions › 5/8″ BSP compression nut
  • #563171
    Bill Phinn
      @billphinn90025
      An old but well made brass bib tap of mine recently started to weep at the water inlet compression joint. Dismantling it revealed that it consists of what appears to be a 5/8" BSP compression nut with an integral olive. The bore accepts 1/2"/15mm pipe.
      I've replaced the tap with a ubiquitous 1/2" bib tap for the moment but I might like to reuse the old tap at some point.
      Does anyone know where I can get 5/8" BSP compression nuts either with an integral 1/2" olive as originally or that accepts a loose 1/2" olive?
      Thanks.
      #28351
      Bill Phinn
        @billphinn90025
        #563177
        DC31k
          @dc31k
          JTM Plumbing
          TB72 3458 5/8" BSP F to 3/4" BSP M bush
          DZR02 1534 3/4" BSP F to 15mm compression
          #563191
          Bill Phinn
            @billphinn90025
            Posted by DC31k on 17/09/2021 15:18:49:
            JTM Plumbing
            There wouldn't be enough room laterally to fit those in, unfortunately.
            #563206
            Bill Phinn
              @billphinn90025
              This is the nut in question, btw. It looks like it did consist of two parts, but in my case the olive has effectively welded itself to the inside of the nut:
              Edited By Bill Phinn on 17/09/2021 18:39:01
