Boiler super heater take out port
Home Forums General Questions Boiler super heater take out port
  • #394581
    Alec Ryals
      @alecryals60900
      Hello Folk;s
      I'm putting a super heater in the fire box of my model P.M. boiler #2 I have added 4 extra fire tubes as well like a Stuart boiler but not sure if its okay to take the output of the super heater on the same level that its at ? Or should it be above say the water line ? being dry steam i don't see any issue except when it cold, Any thoughts or suggestions would be Greatly Appreciated..
      THank You
      Alec
      #26425
      Alec Ryals
        @alecryals60900
        Super heater output
        #394694
        Brian G
          @briang
          I assume the horizontal boiler with the dome Alec. I am a little confused, are you planning on feeding the superheater with water or using an internal pipe from the steam space down to the bottom of the boiler?
          Brian
          #395091
          Alec Ryals 1
            @alecryals1
            Hello Brian,
            Yes its for the super heated steam it comes out the steam dome then goes above the ceramic burner then I'm thinking of taking it out the side right there hence their is no room else were .
            Thank You for Your reply
            Alec
            #395092
            Alec Ryals 1
              @alecryals1
              Hello Brian,
              I found a way to bring it out about the water line but I wonder if it makes any differance ?
              Thank You
              Alec Ryals
              #395105
                As a superheater heats steam you need to feed it with steam and this can only be drawn off above the water line.
                Feeding a tube from below water level and passing that through the firebox will be more like a flash steam boiler and not what you want.
                #395110
                Alec Ryals 1
                  @alecryals1
                  Hello,
                  Sorry i fiquired it out but explained it wrong !
                  Thank You For Your Time
                  Alec
                  #395207
                    Sounds a bit like the way that Mamod ran the steam offtake from the top of the boiler and down under into the flame from the meths burner, en route to the oscillating cylinder..
