Gearing Myford S7
Gearing Myford S7
Home Forums General Questions Gearing Myford S7
  • #328431
    Kenneth Biström
      @kennethbistrom
      Hello everybody!
      I am Kenneth, from Sweden, and I just bought a Myford Super 7 (metric) from 1961,with the Norton gearbox.
      There seems to be a lot of knowledge here about the Myford. So here comes my first questions (or point me in the right direction):
      I wonder what I would need to do with the gear drive to cut both metric and imperial threads?
      Is there any difference between gearboxes (metric/imperial)?
      Regards Kenneth
      Kenneth Biström
        @kennethbistrom
        Gearbox etc
        #328445
        Thor 🇳🇴
          @thor
          Hi Kenneth,
          Welcome to the forum and congratulations with your lathe. I assume you have the gearbox manual? Have you checked some of the previous threads on the theme? Here are a few:
          ***Link***
          ***Link***
          ***Link***
          Thor
          #328446
          Brian Wood
            @brianwood45127
            Hello Kenneth,
            Welcome to the Forum, I feel sure you will find it helpful and interesting
            To answer your question. Are you quite sure your S7 is equipped with a metric gearbox? To my knowledge Myford never made a metric version nor for that matter fitted those lathes with a 3 mm pitch leadscrew to match up
            You might be referring to cross slide and top slide feed screws, there are metric versions of those.
            If you can post a picture of the gearbox pitch plate it would settle the issue. To do that you create an Album of your own into which you install pictures or print and then post that material onto the forum thread.
            Regards Brian
            #328447
            steamdave
              @steamdave
              If you are not already a member, I would recommend that you join the Yahoo group for Myford lathes.
              https://groups.yahoo.com/neo/groups/myfordlathes/info
              Lots of very helpful knowledgeable folk there.
              The Emerald Isle
              #328551
              Kenneth Biström
                @kennethbistrom
                Thanks guys!
                I have a manual but it seems to be missing pages, thanks Thor!
                I don´t think the gearbox in metric, it was just a question. I think I have the metric conversion gears though. The slide feed screws are metric.
                I will take some photos and I will also check out the Yahoo forum.
                Regards Kenneth
                #328587
                daveb
                  @daveb17630
                  There are two versions of the Myford Series 7 gearbox, one for the UK and one for the USA (for Unified thread pitches, the text on the ratio label is blue.
                  Metric Myford lathes have Metric feedscrews. All Myford Series 7 leadscrews and gearboxes were Imperial.
                  Cutting Metric threads on these requires either the Metric conversion set or two or three non-standard gears which allow reasonable approximations.
                  #328616
                  john fletcher 1
                    @johnfletcher1
                    Hello Kenneth, to cut most Metric course threads you will need three extra gears25,33 and 34 these are readily available £9.5 each from Myford here in UK. Also there is a small device which permits the bango to drop further down to fit even more/larger gears to extend the thread cutting range. This home constructed devise was the subject of an article in Model Engineer Workshop some time ago, I have the article. I also have a table showing which gear to fit and which gear box settings you need to cut a particular Metric thread. If send me your email address via a personal message I might be able to help you. John
                    #328626
                      Theoretically, to cut Imperial threads on a machine with a Metric Leadscrew, or Metric threads with an Imperial Leadscrew, you should use a 127T gear in the train. I had one for my ML7, but never used it!
                      A 63T gear will give a close approximation, (often used by owners of mini lathes) and as already said, there are other combinations which will produce threads of acceptable accuracy in the pitch.
                      Others, far more expert than I, will quote the best combinations.
                      My current Far Eastern machine has Metric Leadscrews, but includes a 120T/127T compound gear in the drive train to the Norton gearbox, enabling either to be screwcut.
                      #328628
                      John Haine
                        @johnhaine32865
                        This question of cutting metric threads on an imperial lathe comes up so often that it deserves some prominence here so that people can see the answer without having to ask the question, so to speak! Is there any mechanism for doing such a thing on this website? Ideally a button that would take the reader to a page that brings together the best advice on how to set up the lathe, the change wheel combinations for the various common threads, the tables that people have produced showing all the pitches available for common change wheel tooth counts, and maybe the simple maths behind how to work out the best combinations. Also of course the magnitude of the errors (generally very small) that the approximations produce.
                        #328653
                        Brian Wood
                          @brianwood45127
                          Hello John,
                          That's actually a very good idea.
                          Blowing my own trumpet here, perhaps such a selector could include a reference to my book on the subject which includes lathes other than Myford and presents tables for many other pitches than just metric; there is also a full set of tables for the mini lathes for both languages.of leadscrew.
                          Brian
                          #328701
                          Roderick Jenkins
                            @roderickjenkins93242
                            As alluded to above, the simplest way of cutting metric threads on a gearbox equipped S7 is to replace the 24 tooth output gear from the tumbler reverser (Stud) with one of the gears in the table below:
                            Hope this helps,
                            Rod
                            Edited By Roderick Jenkins on 23/11/2017 15:57:26
                            #328712
                            Kenneth Biström
                              @kennethbistrom
                              Thanks alot again guys!
                              What if a have different gears than the impereal model, a think the lathe is converted to metric with 4-5 different gears? How would I know?
                              I have a photo of the gears in my album.
                              Regards Kenneth
                              #328716
                              Brian Wood
                                @brianwood45127
                                Kenneth,
                                The 'stud' gear that Rod listed in the table above is the only one you need to change. You match that with the gearbox selection to get the result show. I have a feeling that one of these is in error, but can't remember which, maybe someone else can.
                                Your gearing set up in your photos is shown arranged for fine feed. For screwcutting reverse the 57/19 cluster gear held in place with the swinging latch
                                If you have the metric attachment with the gears shown in your picture 2 you need to change the whole banjo and remove the wide 72 tooth gear to replace the set up to get metric results; you can see the attraction of the simpler set up in Rod's table without having to go through all that business as it also denies the fine feed arrangement.
                                Regards Brian
                                #328736
                                Roderick Jenkins
                                  Kenneth,
                                  Your pictures look like the standard imperial set up so the single gear replacement should work. The official Myford metric conversion set **LINK** will give you a theoretically more accurate result but for the expense and hassle in setting up I do not think it is worthwhile. I do use mine for making more unusual leads for helical gears (or candlesticks!) but I was lucky to get it and lots of gears with the lathe. The original table I published some years ago did have a typo in the fine feed table but I have now corrected that.
                                  Rod
                                  #328757
                                    Posted by John Haine on 23/11/2017 10:55:05:
                                    How to guides for both Myfords and Mini Lathes linked to on the 'Processes' page:
                                    Processes
                                    Normally reached from the workshop –> processes on the black band above.
                                    The mini-lathe one includes the maths (I know 'cos I wrote it).
                                    Piero Franchi
                                      @pierofranchi37209
                                      to hijack this topic a tad if you dont mind,
                                      but what are the set of gears one used to be able top buy ????
                                      I happen to get a full set of metric gears with my imperial super seven (with screw cutting gearbox)
                                      #328816
                                      steamdave
                                        @steamdave
                                        Question for Rod – or others:
                                        The smallest metric pitch with the simple gear change a al table above is 2.0 = M15, which is quite coarse for my likely usage. Is there a way to cut smaller pitch metric coarse threads with a simple gear change? M10 – M2 is probably the range I would likely need to cut. OK, M2 – M5 would be by dies, but it would be good to know if it could be done.
                                        The Emerald Isle
                                        #328819
                                        Nick Hughes
                                          @nickhughes97026
                                          Here's another set of tables, that cover a lot of extra pitches and TPI (goes down to 0.20mm pitch for M1.0 Fine)
                                          http://www.model-engineer.co.uk/wp-content/uploads/sites/4/documents/gear%20errata%20tables.pdf
                                          Nick
                                          Edited By Nick Hughes on 24/11/2017 09:39:28
                                          #328823
                                          Roderick Jenkins
                                            Dave,
                                            The left hand column refers to the diameter of the screw and the next column is the pitch for the most common ISO metric fastenings so the table does go down to sizes that I would be unlikely to actually try to cut (doubly so for the BA sizes)
                                            cheers,
                                            Rod
                                            #329265
                                            steamdave
                                              @steamdave
                                              Thanks Rod
                                              Should have studied the chart more closely. And I've had the cataracts removed !
                                              The Emerald Isle
                                              #329270
                                              Brian Wood
                                                @brianwood45127
                                                Posted by Piero Franchi on 24/11/2017 07:57:46:
                                                Hello Piero,
                                                I don't understand the question, can you expand on it please?
                                                Regards Brian
