What are these?
What are these?
Home Forums General Questions What are these?
  • #25589
    Steve Pavey
      @stevepavey65865
      #323738
      Steve Pavey
        @stevepavey65865
        Found in the bottom of a box of bits I bought at a car boot sale:
        Edited By Steve Pavey on 26/10/2017 19:57:24
        #323746
        Gray62
          @gray62
          They look like the tools we used to make for removing the pointer from pressure gauges, could also be a watchmakers tool for pulling clock hands from a taper shaft.
          #323749
          John Reese
            @johnreese12848
            The one on the right looks like a hand jack for pulling the hands off pressure gauges. The point on the screw looks buggered. The one on the left is a clamp for wire on some type of electrical equipment.
            #323760
            John Slaven
              @johnslaven66698
              Hi Steve,
              Definitely a pointer puller for pressure gauges or clock hands. Used one almost every day to pull pressure gauge pointers off for calibration. Check out the link here.**LINK**
              Cheers the Noo
              Oldiron
                @oldiron
                The one on the left looks to be the clamp section of an earth tag. The earthing strip is slipped through the groove, wrapped around a copper water pipe or ground stake and passed through the groove again then the screw tightens it all up.
                #323804
                Steve Pavey
                  @stevepavey65865
                  I wondered if the one on the left was electrical. I would never have guessed the pressure gauge pointer puller though. Thanks very much to all.
                  #323807
                  John McNamara
                    @johnmcnamara74883
                    Given the length of screw travel I wonder if the larger one is a small chain breaker.
                    #323813
                    Joseph Noci 1
                      @josephnoci1
                      Chain breakers tend to be open ended with some sort of slotted guide to align the chain..
                      Edited By Joseph Noci 1 on 27/10/2017 04:28:53
                      #323849
                      john carruthers
                        @johncarruthers46255
                        I made a similar gadget to the one on the right for pulling the pinions from stepper motor shafts on telescope mounts.
                        Thjere are similar fittings to the brass one on the church lightning conductor.
                        #323878
                        Ian S C
                          @iansc
                          An advantage when photographing these sort of things is to place them next to something for reference to size.
                          Ian S C
