Knurling wheels help
Home › Forums › General Questions › Knurling wheels help
  • #301724
    Michael Garbutt 1
      @michaelgarbutt1
      Hi all im half way through building the Hemingway knurling tool but i need some wheels as the ones i have are to wide. any recommendations ? i think they need to be around 1/4 wide and a medium diamond .
      #25293
      Michael Garbutt 1
        @michaelgarbutt1
        #301728
        Spurry
          @spurry
          The ones supplied by Hemingway fit their kits, but they are not cheap, although they are the right size.
          #301729
          Michael Garbutt 1
            @michaelgarbutt1
            i cant find any medium on there though. only seem to be fine or straight
            #301733
            Spurry
              @spurry
              Must admit it was 2011 when I got medium from them. Wheels are 5/8" x 1/4". Might be worth a call though.
              #301734
              Michael Garbutt 1
                @michaelgarbutt1
                may have to call
                #301744
                S.D.L.
                  @s-d-l
                  Posted by Michael Garbutt 1 on 08/06/2017 19:57:14:
                  Have a look at MSC
                  `Steve
                  #301775
                  MW
                    @mw27036
                    I do have to say this shows there are still some advantages to making your own knurling tool, even when cheap ones can now be obtained that do a reasonable job.
                    At least with a homemade one you can make it fit whatever stock bore sizes happen to be available to your area.
                    In other words, you're not necessarily stuck with a design that can't be altered easily.
                    Michael W
                    #301782
                    Roderick Jenkins
                      @roderickjenkins93242
                      I’ve bought 1/4″ bore knurling wheels from various sources and they all seem to be slightly different widths. I’d make my tool capable of taking spacer washers to take up the difference for the narrower wheels.
                      Rod
                      #301807
                      HasBean
                        @hasbean
                        I seem to remember that I bought some from MSC of the right size (some tme ago though)
                        Paul
                        #301953
                        mark costello 1
                          @markcostello1
                          Some one with a surface grinder might be willing to whittle a set down.
                          #301966
                          john barnes 4
                            @johnbarnes4
                            Gloster tooling sell what your looking for. I have fitted HSS medium diamond knurls 3/4" x 1/4" wide x 1/4" bore to a knurling tool I have just made and they work fine. Cost was £12.60 delivered.
                            #326031
                            Spurry
                              @spurry
                              Apologies for resurrecting an old thread, but the info supplied (by me) above is incorrect.blush
                              The correct Hemingway wheels are 5/8" x 3/16" x 1/4" bore. It does seem a bit of an odd-ball size and they are not stocked in many places. Cromwell Tools do keep them but are rather expensive, but Hemingway does not keep much choice. Cromwell have them in Fine, Medium and Coarse versions.
                              Pete
                              #326663
                              thaiguzzi
                                @thaiguzzi
                                phone photos to sept 2017 542.jpgIndeed. Hence I went with 1/4" width wheels. The arms are only 1/2" thick so you only have an 1/8" of steel either side in support, bit I've had no problems yet and it's been worked hard.
                                And because i'm a Cheap Charlie and had a surplus of 3/8" wide, brand name 1/4" bore wheels of different patterns, i made a jig and skimmed them down in my Stent T&CG – now that was fun. Not.phone photos to sept 2017 545.jpg
                                Edited By thaiguzzi on 11/11/2017 13:28:16
