STUCK ON ORTHAGONAL
STUCK ON ORTHAGONAL
Home › Forums › CAD – Technical drawing & design › STUCK ON ORTHAGONAL
  • #654587
    John ATTLEE
      @johnattlee20632
      Dear All,
      Help! I have managed to get my Turbocad stuck on orthagonal so I cannot draw a line at an angle however hard I try. I cant switch it off! Any hints please!
      John ATTLEE
        @johnattlee20632
        #654602
        Roger Vane
          @rogervane67137
          Hi John
          Suspect that you've locked one or more of the axes. i have TC 20, and if you go to the bottom RH corner of the screen there are 3 boxes which show the X, Y and Z positions for the cursor. Beside each one is a tick box which locks the position of the cursor for that axis – make sure that you haven't accidentally ticked one of them.
          Other things to try -.
          1 Look under 'modes / snaps' on the drop-down menus and make sure that you haven't selected 'ortho', as that will allow the cursor to move at right angles only.
          2 With the line tool selected, right click and select 'local snap' – you may have selected ortho here – deselect it and all should be ok.
          Please let us know what you find – good luck
          Roger
          #654609
          John ATTLEE
            @johnattlee20632
            Thank you Roger!
            It was the ortho snap but I did not understand the effect that it would have.
            Many thanks,
