How to profile a bum shaped depression in a 5″G drivers tip-up seat
Home › Forums › Locomotives › How to profile a bum shaped depression in a 5″G drivers tip-up seat
  • #574477
    Greensands
      @greensands
      Here is one for the rivet counters. I would like to be able to fit a couple of tip-up driver/fireman's seats to a 5" gauge loco from oak measuring typically 15" square by 0.1" thick but the problem is that in order to make it look somewhat less slab like I would like to be able to create the bum shaped depression in the centre of the seat. Does anyone have any ideas on just how this might be achieved in 5" gauge? The attached photo shows an example of a full size driver's seat taken at one of our preserved railways.
      #2096
      Greensands
        @greensands
        #574485
          Carve it out with a gouge or some form of disc/drum sander. I assume it's 1.5" square not 15"
          It's an odd shaped bum depression as most people have two buttocks, I wonder if the metal one shown has just become dented over tine by being used as a step
          #574486
          Greensands
            @greensands
            Jason – Size of seat in 5" gauge should read 15/11.8 = 1.25" square.
            #574490
            Mick B1
              @mickb1
              The traditional tool is a travisher. You can get them in various sizes but I shouldn't think that small – assuming it's a scale seat rather than one for a full-size driver.
              Could you use Miliput or suchlike putty with a thumb-pressed depression?
              #574491
              Dalboy
                @dalboy
                It does seem strange that a seat would have one central depression as in the picture as many wooden seats have a U shape depression. And I doubt if standing on a wooden seat would dent it like metal Jason.
                Maybe designed like that so they would not want to sit for long. To recreate this a simple dremel type drum sander will aid in making it because of the scale of it but don't forget the bolt in the middlelaugh.
                Or even a carving Scorp
                Edited By Derek Lane on 06/12/2021 18:52:22
                #574492
                old mart
                  @oldmart
                  Jason, on my screen, the seat shows woodgrain and looks to me like three pieces. To make a replica, I would use a dremel size flap wheel.
                  #574493
                  mike T
                    @miket56243
                    I would go for timber with a finer grain then oak, otherwise it will lookout of scale, unless you intend to paint them.
                    #574494
                    old mart
                      @oldmart
                      That bolt in the middle brings to mind a story about the original jeans made by Levi Strauss which had a rivit in the crotch until complaints were heard from cowboys who got burned sitting around their traditional camp fires. embarrassed
                      #574497
                        Sorry, I can see the grain now I have enlarged it, silvery colour made me think it was metal.
                        #574499
                        Nigel Graham 2
                          @nigelgraham2
                          I'd establish first if the full-size seat for the particular loco or its related classes, had such hollows. (I am not convinced by whatever happened to the one in the photo). However, assuming so, by comparison with other furniture generally the mouldings would be so shallow that very careful sanding, perhaps assisted first with a rasp, ought be sufficient to represent them.
                          I've never had cause to measure furniture to that detail but generally, situpon hollows don't look much more than about 1/4 " or so deep.
                          This does remind me though of a friend who as a Senior Medical Lecturer appears to collect some remarkably naive students, and recounted to me one once asked, "Do women have buttocks? "
                          My friend solemnly assured him they do.
                          Then told me she asked him, "What else do you think we sit on? "
                          #574506
                          Martin Kyte
                            @martinkyte99762
                            You need one of these.
                            Trouble is they are are out of stock at the moment.
                            However now you have got the idea you could make one.
                            regards Martin
                            Edited By Martin Kyte on 06/12/2021 20:28:25
                            #574507
                            Rob McSweeney
                              @robmcsweeney81205
                              A nice sharp bullnose end mill ought to do the job
                              #574523
                              Robert B
                                @robertb
                                The depression isn't very deep. Some 80 and 120, possibly 180, grit paper glues to stick will make that quite quickly and keep the non engineered shape. The seat of pants over a few years will make this or standing on it with hob nails. Windsor chair makes have special tools but on this scale they are not needed. Look for a finer grain. Oak can be distinctly coa
                                rse and not in keeping. Should it have an oil and coal dust patina?
                                Rob
                                #574537
                                Speedy Builder5
                                  @speedybuilder5
                                  angle grinder fitted with sanding disc. Test correct depth of the scallops by putting marking blue on buttocks and sand away the high spots (on the seat, not on the butt….).
                                  Bob
                                  #574539
                                    These are bigger than the scale you need … but the video shows seat shaping:
                                    Edit: __ Here is his tool for the full-size chair seats
                                    Edited By Michael Gilligan on 07/12/2021 08:30:16
                                    #574545
                                    larry phelan 1
                                      @larryphelan1
                                      As Mrs Beeton might advise, "First catch your bum" cheekycheekycheeky
                                      #574546
                                      Greensands
                                        @greensands
                                        Have attached a photo showing a second example of a full sized drivers' seat with an alternative form of profiling which would be easier to replicate in miniature
                                        #574547
                                        Ady1
                                          @ady1
                                          I suppose a bum shaped grinding wheel would generate a bum shape
                                          A foam backed roll of sandpaper?
                                          Edited By Ady1 on 07/12/2021 09:44:55
                                          #574548
                                            Posted by Greensands on 07/12/2021 09:36:59:
                                            Have attached a photo showing a second example of a full sized drivers' seat with an alternative form of profiling which …
                                            … looks worryingly like a shallow catchment vessel surprise
                                            Don’t brake too hard !
                                            Dalboy
                                              @dalboy
                                              I think that sometimes we overlook the obvious solution and that is put it in the lathe and turn it with hand chiselsas a woodturner would do this.
                                              #574565
                                                In ‘our’ defence, Derek … turning a depression, using the lathe, only becomes relevant when you are no longer trying to produce a ‘bum-shaped’ seat.
                                                pgk pgk
                                                  @pgkpgk17461
                                                  Not relevant to a model engine seat but perhaps of interest:
                                                  I recall an old technique for making a seat by lowering bum into a bucket of wet cement, then making a negative from that and laminating between the profiles.
                                                  For the ultimate rowing luxury, a bespoke sliding seat such as here
                                                  Back in my racing days, I found one comfortable seat and pinched it and carried it with me for use in whatever boat I was assigned.,,, still have it among my trophies.
                                                  pgk
                                                  #574568
                                                  Nigel Graham 2
                                                    @nigelgraham2
                                                    The sagacity of this forum knows no bounds….
                                                    Learned discussions on the mysteries of CAD/CAM equipment, programmes and use thereof;
                                                    Advice on identifying and overhauling vintage machine-tools;
                                                    The principles and construction of valve-gears and injectors;
                                                    Photographing the cosmos;
                                                    etc., etc.;
                                                    and now, notwithstanding that I do in fact greatly respect and admire detailing to prototype –
                                                    – detailing to the extent of 1:12 scale botts on seats that in 1:1 scale were probably rarely if ever built to such luxury!
                                                    The enginemen of old are said to have called travelling in the coaches as "on the cushions" …
