stent
stent
  • #617193
    john willman 1
      @johnwillman1
      I have been machining the Stent castings which I bought many years ago. The dovetail on the table does not run its full length and I cannot see any reason for this, especially as the rack is shown extended out from the table. This means there will be little support when the table is to the far left. I wondered if later castings were any different. Unfortunately the casting I have has a large blow hole in the middle, so I am thinking of starting again.
      #20816
      john willman 1
        @johnwillman1
        table slide
        #617201
        Nigel Graham 2
          @nigelgraham2
          You are not the first to spot this apparent design flaw that results in the table nearly falling off the end, and thereby hangs an solution.
          To clarify, the ends of the dovetails are open – the table simply overhangs them at each end. Why, I can't see either, but it may not matter unless you are sharpening long-series cutter flutes.
          Giles Parker published a simple solution, in MEW years ago – though the magazine used an un-modified Stent for its cover photograph.
          Essentially Mr Parker rotated the column etc. 180º on his version, to place the spindle inboard, approximately over the middle of the slide's mid-stroke.
          Ref:
          Parker, G. Stent Modifications. Model Engineers' Workshop, No.208, Aug/Sept 2005.
          #617222
          IanT
            @iant
            I have this MEW article John – PM if you would like a copy
            IanT
            #617232
            JES
              @jes
              Model Engineers' Workshop, No.108, Aug/Sept 2005.
              Just a small correction
              JES
              #617280
              Nigel Graham 2
                @nigelgraham2
                Oh yes. 108. Thank you for that.
                Wrong glasses on!
                #617320
                bernard towers
                  @bernardtowers37738
                  If you look at the Clarkson t & c grinder the rack sticks out on that and its one of the best regarded grinders. The stent is really just its baby. I have been using mine (short base ) for 35+ years without any real problems. The only part I did not like was the rear mounted table stops so made the popular design that fits on the front of the machine.
                  #617385
                  john willman 1
                    @johnwillman1
                    Many thanks for your replies. Perhaps I had better get on with the rest of it, then review it later. Too many years have passed already !
