Fobco drills
Fobco drills
Home › Forums › Workshop Tools and Tooling › Fobco drills
  • #610344
    Michael Callaghan
      @michaelcallaghan68621
      Hi, is it still possible to get spindle seals for fobco drills. Thanks
      #20770
      Michael Callaghan
        #610352
        mgnbuk
          @mgnbuk
          You might struggle if the seal is a bespoke part – it appears that O'Brian Manufacturing (which seems to have been the last iteration of O'Brian Engineering who made the Fobco drills) was dissolved in April 2021.
          Could you post details / pictures of the seal, which may aid identification ?
          Nigel B.
          #610354
          noel shelley
            @noelshelley55608
            IF it is a standard seal it will be known by its OD X ID X Width. Often now even imperial sizes will be expressed in metric. There are several types of material, nitrile, Viton Etc Viton has the benefit of higher temperature and a stainless spring, R23 is a double lip seal, which in this application may be a denefit to. Most good bearing suppliers should be able to help you. Good luck Noel.
            #610373
            Michael Callaghan
              Thanks chaps.
              #610379
                Seals, like bearings, are usually a standard size made by industry suppliers. Would be rare for a machine manufacturer to make their own special. Measure it up and talk to a bearing supply house.
                #610385
                Dave Halford
                  @davehalford22513
                  Take the seal out make a note of the bearing number engraved on it and ask for a seal for that number.
                  #610397
                  Michael Callaghan
                    Thanks again
                    #620138
                    Nick Riddiford
                      @nickriddiford37031
                      Hi Michael, did you manage to locate any seals? I have a 7/8 that is dripping from the quill/spindle and I'm assuming there must be an oil seal in there that's had it. Any advice will be appreciated.
