Where to buy a single 5mm transfer punch?
Home › Forums › Workshop Tools and Tooling › Where to buy a single 5mm transfer punch?
  • #577769
    pcb1962
      @pcb1962
      Hi, the 5mm transfer punch from my cheap Chinese set has become too blunt to use. I'd like to replace just this one size with one of good quality, however all I can find is the ubiquitous cheap set. Does anyone know where in the UK or Europe I can buy a single 5mm quality punch? Thanks
      #20555
      pcb1962
        @pcb1962
        #577770
          Anneal your blunt one, turn a new point and then harden and temper it again.
          #577778
          Rod Renshaw
            @rodrenshaw28584
            Further to Jason's suggestion above, I have found it possible to re-sharpen my punches when needed without annealing and re-hardening by using a carbide tipped lathe tool- the steel is hard but not that hard. Mine are a cheap generic set which sound as if they should be similar to yours, but not all sets may be the same hardness.
            Rod
            #577779
            Mike Poole
              @mikepoole82104
              A piece of 5mm silver steel will make a satisfactory punch, it’s the right size and simple to harden and temper after you have machined a suitable point.
              #577781
              pcb1962
                @pcb1962
                Thanks all, I've never done hardening and tempering before so I guess this is my chance to have a go.
                #577782
                Pete Rimmer
                  @peterimmer30576
                  Stick it in your battery drill chuck and offer it up to your bench grinder at the point angle. A very light lick on the grinder will restore the point.
