Blank Tee Nuts.
Blank Tee Nuts.
Home Forums Workshop Tools and Tooling Blank Tee Nuts.
Viewing 25 posts - 1 through 25 (of 32 total)
  • #576511
    Bo’sun
      @bosun58570
      Good morning,
      Yes, I know I can make them, but I'd rather be model making than tool making.
      I want to use an M6 clamping stud in a M8 tee nut. I had considered loctiting a piece of M8 stud in the tee nut and re-taping it M6, but with an M8 core dia of 6.5mm, I thought it would be a bit too close.
      So, can I buy M8 blank tee nuts?
      #20544
      Bo’sun
        @bosun58570
        Does anyone supply them?
        #576514
          Posted by Bo'sun on 24/12/2021 10:18:20:
          Good morning,
          My emboldening. Don’t you just need to turn down to 6mm (or slightly less?) and use a die?  I don't think you would buy M8 holes without thread.🙂
          Edited By not done it yet on 24/12/2021 10:28:01
          #576522
          Bo’sun
            @bosun58570
            HI ndiy,
            By blank I meant with no hole, so I could drill and tap for an M6 stud.
            #576525
            Dave S
              @daves59043
              They don’t need to be t shaped.
              I would just get some hot rolled bar of appropriate width and lop a chunk off.
              Bo’sun
                @bosun58570
                As they say, the simple solutions are sometimes the best. "Can't see the wood for the trees" and all that. I should get enough threads for M6.
                Thanks Dave.
                #576538
                An Other
                  @another21905
                  If you only need some temporary holding, there was a thread here which dealt with using 'carriage' bolts – get some M6 Bolts, flatten the sides of the head so it fits the slot, and you're done.
                  #576541
                  HOWARDT
                    @howardt
                    Yes you can buy them, WDS tooling, expensive for what they are.
                    #576542
                    bernard towers
                      @bernardtowers37738
                      T nuts are freely available from a few of our usual suppliers
                      #576543
                      Ex contributor
                        @mgnbuk
                        WDS
                        supply Tee nut blanks, though being an industrial supplier they are not "bargain basement" prices.
                        Nigel B.
                        Howard beat me to it !
                        Edited By mgnbuk on 24/12/2021 11:46:19
                        #576550
                        David Jupp
                          @davidjupp51506
                          You can also buy M8 male to M6 female threaded sleeves.
                          #576551
                          Nigel Graham 2
                            @nigelgraham2
                            Beware though –
                            – make sure whichever route you choose that the studs or screws do not bear on the bottom of the slot. That is a recipe for breaking lumps out of the table.
                            Properly-made T-nuts have a trap-point to prevent the stud going right through the nut.
                            #576553
                            KWIL
                              @kwil
                              Posted by Dave S on 24/12/2021 10:57:30:
                              Beware of this approach, you have less metal in contact with slot underside and run the risk of damaging the slots. More inclined to tilt as well.
                              #576554
                              An Other
                                @another21905
                                Why should using a piece of appropriate sized hot-rolled bar have less metal in contact with the underside of the slot be, or a bigger risk of damaging the slot? – nothing to stop using a piece of thick steel strip the same width as the slot, and as long as you like, which would spread any load.
                                If a piece narrower than the slot is used, then yes, it would increase the risk, but I don' think anyone is suggesting that.
                                #576583
                                Dave Halford
                                  @davehalford22513
                                  Posted by KWIL on 24/12/2021 12:11:01:
                                  That would be true if m6 thread nuts are used in m8 thread size slots, Bosun is trying to avoid that.
                                  #576586
                                  old mart
                                    @oldmart
                                    I bought a length on ebay from one of the well known suppliers and its ok, but I prefer to make my own which fit the tee slots better and bears on the outboard ends of the tee. Mine are 50% longer than the ready made ones.
                                    #576593
                                    Dalboy
                                      @dalboy
                                      Good morning,
                                      I would have thought that by the time you have got the answer on here then ordered them wait for them to arrive you could have made some and still spend time model making and even possibly have the part finished which you wanted them for in the first place.
                                      I have made many wooden models in the past and time making jigs and such is always well worth doing
                                      #576639
                                      Clive B
                                        @cliveb55652
                                        Rotagrip supply blank Tee nuts in various sizes at reasonable cost:-
                                        Blank tee nuts
                                        #576643
                                          Posted by Clive B on 24/12/2021 20:49:19:
                                          … and in an interesting range of sizes:
                                          **LINK** : http://www.rotagriponline.com/datasheets/teenuts.pdf
                                          It would be worth checking the slot dimensions quite carefully.
                                          Mike Poole
                                            @mikepoole82104
                                            Rotagrip supply semi finished T nuts that have no hole Rotagrip
                                            #576659
                                              Yes … as mentioned by Clive
                                              ’though the datasheet of sizes doesn’t include those
                                              [ I suppose we have to guess that they have holes of zero dimensions ] devil
                                              Ramon Wilson
                                                @ramonwilson3
                                                If you can't spare the time to mill two rebates on a short length of mild steel and cut it into one inch lengths before drilling and tapping it doesn't bode well for model making Bo'sun.
                                                It will take longer to respond to this thread than to make a six inch length so I would just get on with it – you'll surprise yourself just how quick you can make half a dozen
                                                Happy Xmas – Tug
                                                #576732
                                                old mart
                                                  @oldmart
                                                  It's very likely Rotagrip that I got my length of tee section which was probably 300m long.
                                                  #576737
                                                    As mentioned earlier if making nuts for undersize studs I don't see much point in making them Tee section.
                                                    Take the photo below, in the middle are the Tee nuts I commonly use on my mill which has 12mm slots and nuts are tapped M10. on the right is an Emco nut for their M6 studs. On the left is the "bit of bar" that I used to make some nuts for use on the larger mill to accept M6, it's thicker than the Emco so less chance of pulling out being 1/4" thick rather than the Emco 5mm overall and a larger contact area than the emco's. Rectangular shape allows me to also use them on the rotary tables' 10mm wide (M8) slots too.
                                                    #576740
                                                    Bo’sun
                                                      @bosun58570
                                                      Thanks Jason.
