Which bearings for a grinder?
Home Forums Workshop Tools and Tooling Which bearings for a grinder?
  • #568996
    Grindstone Cowboy
      @grindstonecowboy
      Was recently given a double ended bench grinder which needs new bearings. The existing ones (pretty sure they're original) are metal shielded both sides. Just wondering if there would be any advantage in getting rubber sealed ones instead – the cost difference is neglible.
      It's an Ajax unit, 750 watt, looks to be from the 60s or 70s. There may also be an issue with the capacitor, but one step at a time…
      Thanks, Rob
      #20476
      Grindstone Cowboy
        @grindstonecowboy
        Shielded or sealed?
        #569004
          Can’t ell how much work it might have done since new, but how long are you expecting it to last? I would not be surprised if the lube has simply dried out a bit over that period. Go with the bearing supplier’s recommendation – bearing quality is likely a better metric.
          Running out of balance could be another reason for the bearings to wear.
          Edited By not done it yet on 30/10/2021 19:38:51
          #569010
          AJAX
            @ajax
            I'd like an Ajax unit — it would go with my forum nickname.
            Capacitors are easy enough to replace, and if it still has the original one then it's probably about time.
            #569030
              Since grinding dust will be flying about, 2RSS would be my choice. More friction, but I'd live with that.
              Probably bearings worn because they are shielded rather than sealed
              #569060
              David George 1
                @davidgeorge1
                Hi I replaced shielded bearings with rubber shielded bearings on a grinder and the bearings heated up the housing quite a lot. Slight friction of rubber shielding at that speed caused heat. Check with a proper bearing supplier as to correct bearing. Right bearing right place. With metal shielded bearing it is still sound ten plus years later.
                David
                #569073
                martin haysom
                  @martinhaysom48469
                  if the originals lasted 50/60 years i would stick with the same type
                  #569079
                  Grindstone Cowboy
                    @grindstonecowboy
                    Thanks everyone for your advice. Good points from David and Martin, you've convinced me to stick with shielded. If they wear out again before I do, I can always replace them again smiley
                    Rob
