Warco milling machine speeds
Home › Forums › Workshop Tools and Tooling › Warco milling machine speeds
  • #20470
    Michael Callaghan
      @michaelcallaghan68621
      #568224
      Michael Callaghan
        Hi, I have an old warco milling machine with the belt drive. Can anyone please give me the speeds of the mill in each belt position. Thanks
        #568226
        DiogenesII
          @diogenesii
          The big one, with 12 speeds on three pulleys? ..the Major gives:
          #568227
          Dave Halford
            @davehalford22513
            Then there's the Minor and the Economy and didn't they do one or two with only two pullies.
            My crystal balls batteries have gone flat.
            #568231
            DiogenesII
              @diogenesii
              ..innit..smiley..
              TBH, you'd be better to get a cheapy chinese tachometer of the internet and do a quick rating in any case, I doubt the spec's have remained static over time, and as Dave points out, it might be one of several different models.
              #568235
              Russell Eberhardt
                @russelleberhardt48058
                Posted by Dave Halford on 25/10/2021 19:01:16:
                Yes, my ZX-15 has two four step pulleys. Now much better with inverter drive.
                Russell
                Edited By Russell Eberhardt on 25/10/2021 19:38:36
                #568244
                Glyn Davies
                  @glyndavies49417
                  On my 2017 VMC, this is the speed sticker on the belt guard:
                  This is the pulley arrangement:
                  This is the speed table I constructed having measured each speed with a tacho:
                  #568407
                    The Warco Economy has four sheaves on motor, Intermediate and Quill pulleys
                    These are supposed to give speeds, on 50Hz Single Phase mains of:
                    90,170, 200, 250, 280, 360, 600,700, 950, 1290, 1590, 2150 rpm
                    #568422
                    David Caunt
                      @davidcaunt67674
                      Posted by Glyn Davies on 25/10/2021 20:51:08:
                      As the highest speed is correct it might be you are suffering from belt slip at the other combinations.
                      #568443
                      Michael Callaghan
                        Thanks to you all.
                        #568466
                          My Economy shredded the primary belt within 6 months of occasional use.
                          Realigning the motor with the intermediate pulley (Straight edge over the two pulleys ) has meant that the new A30 belt, like the original,secondary, has survived over 20 years of use.
