Jason have made correct drawing of what I want to make. Sadly I don't have access to autocad/autodesk software to make such a nice drawing.
@Jason,
You can round corners of plate on lathe as long as radius is such that similar plate could be made by milling round barstock. Unfortunately it is not the case in my situation.
These cutters are cheap.
HSS variete of 8mm radius you can get from China for $10 and solid carbide version below $80. Free p&p. Shank is 20mm so ER32 collet of this size will do.
Those for 6mm are twice cheaper with 16mm shank.
So would you go for 45 deg angle and a single pass?
My plate is 6mm thick mage of 6mm steel gauge plate, 45HRc (Toolox 44).
@Henry Artist,
This will be a slider used in quite elaborate spindle of rotary vacuum pump.
Edited By Martin Dowing on 27/11/2020 09:38:46
Sorry to edit your post but the supplier linked does not meet the code of conduct conditions on the forum
Edited By Mike Poole on 27/11/2020 09:50:31
