Die filers for beginners?
Home Forums Workshop Tools and Tooling Die filers for beginners?
  • #19439
    Chris V
      @chrisv
      #426212
      Chris V
        @chrisv
        Hi all, Ive been looking at the Martin Model and Hemingway die filer kits as a potential first project on my Myford ML1, that has 3-1/8" centre height. I have a vertical slide for it but I don't have a seperate mill..I do have a decent size bench drill. Oh and I'm a beginner.
        Putting aside the table which I figure I could fabricate from mild steel (is cast iron better for machine tables such as this?) I'm wondering if I have the size capacity to make one up???
        I prefer the look of the Martin model but for some reason figure the Hemingway might be the way to go.
        Could any makers of either of these two please comment?
        Many thanks
        Chris.
        #426617
        Chris V
          @chrisv
          Good afternoon, can anybody help at all with my last posting, copied below?
          Many thanks
          Chris.
          #426621
          ega
            @ega
            Did you mean the Hemingway Sawing and Filing Attachment (I couldn't see a die filer on their website)?
            Sorry I can't help directly but Hemingways will surely tell you if the attachment will fit your lathe.
            #426623
            Chris V
              @chrisv
              Thank you ega, yes I did mean the sawing & filing attachment. I have emailed them this afternoon but would also like views from anybody who has built one, and is cast iron (rather than mild steel )so important for a small machines table such as this.
              #426624
              Brian G
                @briang
                There is also Harold Hall's design, made without castings Link . I had wondered about this for a future project (unfortunately it would join a very long queue with very slow progress) as the reduction drive means that the lathe (or indeed any spare motor) could be run faster.
                Brian
                #426638
                Chris V
                  @chrisv
                  Thanks Brian, yes I'd seen that, for me on aesthetic grounds its if all else fails, I'd much rather have castings (-:
                  #426646
                  steamdave
                    @steamdave
                    Do you want the die filer as a working tool or as a machining exercise?
                    If a working tool, bearing in mind the size of your lathe, and the future projects you may make with it, have you considered a bar stock version? There are at least two die filers on homemadetools. The first of the two following links is very simple and would get you going pdq. The second looks to be a bit more 'workmanlike' and closer to a machine made from castings and maybe more to your liking.
                    https://www.homemadetools.net/forum/miniature-die-filer-27294#post36802
                    https://www.homemadetools.net/forum/filing-machine-12989#post15657
                    I know you like the look of castings. The problem may be that if you butcher one of the Martin Model castings, especially them coming over the water from USA, it could be an expensive mistake.
                    The Emerald Isle
                    #426658
                    Chris V
                      @chrisv
                      Thank you Dave, more as a useful bit of kit than an exercise I think. If a ready made Martin M version turned up I'd have it. I could have used one for work this week!
                      Both are interesting links, though neither work for me. Yes I'm aware of the shipping and import duty and as you say if I mess up…….
                      I will keep on pondering! (-: I may order the drawings only to see what exactly is involved.
                      Cheers
                      Chris.
                      #426661
                      KWIL
                        @kwil
                        Hemingway used to allow purchase of drawings ahead of main order and would allow credit of cost of drawings if kit ordered later. You could ask them.
                        #426670
                        Chris V
                          @chrisv
                          Yes thank you KWIL, I think I saw that they do…..
